Author Topic: Carb Float - on the third one - why?  (Read 3944 times)
SueG
« on: May 19, 2007, 11:44:43 AM »
Our 126 carb float has been replaced three times now - they are tending to last about 2 weeks before they fail, and start filling with fuel (our 126 has been back on the road since the middle of March 07).  We've got a brand new one to put on (Thanks Franco!), but are worried that the fuel additive is damaging the float. The additive we use is Castrol Valvemaster.  Has anyone else had this experience, and if so, how can we get over it!!.....
Many thanks
Sue
« Reply #1 on: May 19, 2007, 11:52:59 AM »
hi Sue welcome to the site, thats quite a alot of times to have to keep replacing it, is it a BIS youve got? i assume its aircooled then if youre using castrol valvemaster, ive replaced my float once in the past. It had solder marks where someone had tried to repair it. Ive seen lots of patched up floats, so make sure you get a good one. (i got my float off Franco from Ricambio)
Im wondering if your float is adjusted properly so it sits where it should in the chamber. Castrol valve master wouldnt affect the float, i use it with no probs. Are the floats definatly sinking? (easy test is to stick it in a bowl of water and check for bubbles, then give it a shake to see if you can hear anything inside) Alternatively you could find a plastic float from a different carb that has the same dimensions.
there must be a reason for it keep doing this, and im sure someone on here will give you the correct advice/answer.
regards
« Reply #2 on: May 19, 2007, 11:58:51 AM »
Brass or plastic float?
Can you see where it's leaking from?
I would be very surprised if it's the additive causing the problem, more than likely a batch of faulty floats or the float is adjusted incorrectly?
« Reply #3 on: May 19, 2007, 12:01:42 PM »
yes Chris, my guess is its not adjusted properly, so its getting bashed about inside the chamber. did they ever do a plastic float?
regards
SueG
floats - and floats - and floats!
« Reply #4 on: May 19, 2007, 12:07:02 PM »
Hi Chris (and Chris)
Yes - definitely got petrol in them - you can hear the fluid inside, and see the telltale petrol as it seeps out.  The three floats we've used were sound but used, no signs of extra soldering.  We are going to paint the seam on the new carb with some cellulose paint to protect it a bit better.
Am reassured that you've only had to replace once - here goes!
Interesting point about the adjustment - how can we tell if its OK, and how would that cause the perforation?  It runs a dream in between sudden stops!
Ta
Sue G
SueG
« Reply #5 on: May 19, 2007, 12:16:47 PM »
Does anyone know a source for plastic floats?  Its NOT the Bis one, its 40mm long (kinder egg size!) 'cos "Dotty the 126" is an aircooled 1987, which we've had since 1991.
Added grief is from daughter when car won't start at 8.15 in the morning - and Mum has to get out of bed on only day off to take to work!!
Sue
« Reply #6 on: May 19, 2007, 12:33:15 PM »
Sue
I would not use cellulose paint anywhere near the carb seam! If it dissolves and gets into the jets etc, you will have big problems!
This may help with your float level adjustment
http://fiat126clubuk.freepgs.com/126manual.pdf
« Reply #7 on: May 19, 2007, 12:50:19 PM »
aircooled and BIS floats are the same, i dont think you can get plastic ones. Funny enough, when i was having probs with my float i was tempted to fabricate a temporary float out of the kinderegg plastic! as it was going to take a while for the float to arrive.
Where abouts are you?
Chris L
« Reply #8 on: May 20, 2007, 11:42:56 AM »
question what exactly happens when your floats fails? as i am having a bit of agro at the moment where my car runs fine then when i come off the accelerator the engine dies , it will restart fine but must use a bit of choke but as soon as i try to pull away will die on me again. i can only pull away by really revving the engine so that when it dips it doesnt die on me . once going its okay again till i ease of the accelerator? chris as for kinder egg what a surprise!! hope you take the toy out first, it wouldnt work anyhow cos it must weigh the same as the old float.i do believe the solder that is on new floats is to add weight so the are spot on .
« Reply #9 on: May 20, 2007, 12:11:17 PM »
spot on with the extra solder mick,as for what happens,your carb floods,in extreme cases it pours out over the engine.................
SueG
« Reply #10 on: May 20, 2007, 08:49:23 PM »
Hi Chris L
Franco sent us a float that he said was for a BIS, it was nearly 50mm width, and bigger circumference, ours is 40mm width.  Car now running - sort of - George (the daughter) rang at 2.05 am (yes a.m.) this morning to say 126 wouldn't start, felt like choke wasn't working.  Luckily she works at a local holiday park, and they have a Harley Davidson convention this week, one of the 900 bikers came to the rescue.  Cable is either broken or disconnected - yet another thing!
We live in Dorset .....
Regards
Sue
« Reply #11 on: May 21, 2007, 09:07:12 AM »
all this talk of floats made me think so i went and looked at the two in the carbs ive been using and one is knackered the one on the car appears to be ok so i am stumped as to whats going on...
sue its nice you have such a close relationship with your daughter that she can ring you a 2am! i shall start keeping my kids in the shed so they dont get the same sort of ideas when they get older...
hope you get it sorted soon , and buy your daughter a short course on motor mechanics at your local college for christmas. that way you will sleep easier :lol:
