Author Topic: cooling an not working.  (Read 3831 times)
neil 126
« on: May 13, 2007, 07:01:06 PM »
hi guys, i have been working on my girls bis for the last two months, welding up the floor pan were it got eaten by the dreaded tin worm, also done a lotal carb refurb and just flushed through the cooling system, what a lot of mud there was. any way having refilled the cooling system, and bled it propperly, the cooling fan now doesn't come on. what could be causing this? the solenoid switch to the right of the carb that opens up the vacume to increase the revs is working and the revs increase to compensate for the increased electical load but the fan still is not working.
would apreciate any advice on this as it as been driving me mad today.
cheers neil.
learnt it the hard way
« Reply #1 on: May 13, 2007, 07:15:02 PM »
all i know is the fan comes on very late,ive spent ages watching my old bis waiting for the fan to kick in.......i can tell you that i have all rad/fan bits sitting in my yard if you need them,free,just pick up the postage  :wink:
« Reply #2 on: May 13, 2007, 07:48:17 PM »
First of all check the fuse.  If this is blown it could be to do with a faulty two stage switch!  Mine was faulty on the first stage causing it to blow the fuse and then of cause it would overheat.  Once you have fixed this think about wiring a manual overide switch so you can turn the fan on earlier and therefore cool the car better!  As for the fan coming on very late it certaily does, mine dosen't come on until two notches B4 the red zone so that is why I put in a overide.
Hope this helps.
neil 126
« Reply #3 on: May 14, 2007, 07:19:16 PM »
thanks for the input, the fans fuse is good and not blown.
if the soleniod switch that increases the revs is working then the fan should be working. dose the thermostat in the radiator triger the solenoid? is this write?
perhaps there is a fractered wire.
is the fan a 2 stage fan? i'm sure my bis witch is working and used daily only one stage. on or off. and the temperature gauge never goes past half way.
« Reply #4 on: May 14, 2007, 07:48:55 PM »
if the vacuum solenoid switch is working the the thermastat switch on the radiator is is working, have you checked the fan relay thats mounted in the fuse box? also check the fan connectors in the engine bay,
failing that i'd check the fan with a 12volt batt and then the wiring for continuity. the bis fan is a 2 speed but mine seems to be the same i have only heard it on one speed.
« Reply #5 on: May 14, 2007, 08:05:51 PM »
you said youve been playing about with the carb, make sure the vacume advance tubes are on correctly, ive made this mistake plenty of times, this will speed it up, but doenst explain why its not cutting in at all.
My fan didnt cut in once, because of a split/corroded wire.
regards
Wozza
« Reply #6 on: May 15, 2007, 11:25:06 AM »
I used to have the same problem neil,but when i had my carb reconditioned they removed the vacuum unit on the side of it. They said it wasnt necessary!! :roll: . So i ended up wiring in an override. You could retreive the two connections for the heated rear window from the loom beside the petrol filler neck, and use those. They carry up to 30 amps so will power the fan and your dashboard will be un-spoilt. This has worked for me, but then i only use my bis for six months in summer each year.
neil 126
« Reply #7 on: May 15, 2007, 10:43:29 PM »
thanks guys for the help.
whitch is the relay for the fan? i have spares so could just swap one.
i am not keen on putting in an veride as it will be my girlfriend that is driving ths one and i want to make things as easy for her as possible, she is already worried that she has forgoten to drive a manual let alone one that has no syncromesh on first and reverse.
« Reply #8 on: May 15, 2007, 11:32:46 PM »
punkydog
« Reply #9 on: May 19, 2007, 09:17:43 AM »
Check the resistor and connections sited in the radiator cover at the bottom corner nearest to the rear.
Brian
neil 126
problem soved
« Reply #10 on: May 20, 2007, 10:31:57 PM »
thanks guys for all your help.
i have now fixed he problem, it was a corroded wire, the connections at the near side wheel arch had all corroded where the water soden insulation had kept them nice and moist for many years.
