Author Topic: leaf springs difference in height  (Read 1548 times)
« on: May 13, 2007, 08:09:42 AM »
i have 3 leafsprings now and have taken a photo of them to show the differences in height , but i cant post it up on here . i will post it into the garage section in the 1986 matt black 126 garage . have a look  the original is obvious the middle spring is from 500 mania and the front is a polish spring that is lowered but is not reverse eye . i will put the 500 mania spring on to see how low it takes the car.
i have put a facet fuel pump onto the polski now along with an oil catch tank and tried to clean up the engine bay in general . i need to remove the thermostat housing for repainting then it will look a tad better . cheers mick
« Reply #1 on: May 13, 2007, 09:48:18 AM »
alright mate, where the best place to get a lower leaf sping? are they the same as 500?
Re: leaf springs difference in height
« Reply #2 on: February 25, 2009, 07:35:38 PM »
Mick, seen the pics in Photo section, How did you intall the oil catch tank?
Mine has 2 hoses, then a cap on the top. I can understand one is for oil in but the other is it for a filter or does a filter screw on the top???
« Reply #3 on: February 25, 2009, 09:14:07 PM »
by the looks of it yours needs a filter on one of the pipes make sure its higher than the catch tank in its location otherwise if you ever lost oil via this route it will just spill out before the tank does its job.
