hi,if you want a cheap alternative you could always put a few washers on the hinges so it spaces it more away from the wing,126s have huge door gaps anyway,
it will also work if your door has dropped just put more washers at the bottom hinge to push the door up,
as for the check strap,you could take it out and shorten it just cut about an inch off(or how ever much is required) where it clips in,bend the corner bits back to the same shape with a vice and a hammer,then hey presto put it back in and the door wont go as far............ :wink:
