flip,i dont understand,the timing is not adjusted at the carb.............and adjsting the idle screw at the carb will not make it pop or otherwise.....you must have another problem if the car wont idle....
adjusting the IGNITION timing at the distributer on a car that was running ok is the last resort anyway,(and if you do,mark the position of the dizzy relative to engine crankase) however,the points gap does close and that throws the IGNITION timing out,(which would affect idle speed)so those should be suspect,otherwise,suspect carb problems,rough/uneven idle/stalling could be loose carb mounting nuts,dirty aircleaner/air cleaner set to winter/loose spark plugs,vacuum pipe disconnected or dirty carb,all these things should be checked before undoing and swinging the dizzy around.
:cool:
