Author Topic: battery light is on  (Read 2655 times)
Frank126
battery light is on
« on: May 05, 2007, 07:21:58 PM »
Hi. all 2 days ago I started my bis in the morning and the battery light remained on all the while, I noticed the more I pressed the throttle pedal the dimmer it went, I used it yesterday with the same problem but everything worked fine until this morning I found a flat battery, I charged the battery and refitted it, but still the light is still on, anyone had a simliar problem?
fiatfsm
battery light is on
« Reply #1 on: May 05, 2007, 07:42:37 PM »
you have a charging fault, could be a faulty alternator.
battery light is on
« Reply #2 on: May 07, 2007, 11:35:06 AM »
Yes I suspect alterator  as this happened on mine, changed it and it stopped.
battery light is on
« Reply #3 on: May 07, 2007, 11:44:46 AM »
word of warning with alternators,if you flatten your battery and need to re charge,you must disconnect the battery!.you can burn out the gubbins inside the alt if your not carefull.................
Frank126
battery light is on
« Reply #4 on: May 11, 2007, 07:04:06 PM »
yep u were right it was the alternator, somthing inside, the elctrician told me its common he refurbished it and its working fine now :D
totyfox
battery light is on
« Reply #5 on: December 17, 2007, 08:45:12 PM »
i have the lamp of battery on when i am on no load and the car does not stop i have heard thats right to be the lamp to be light on the no load speed is this right?
