Author Topic: timing question.  (Read 2845 times)
fiatfsm
timing question.
« on: May 03, 2007, 09:27:15 PM »
did some work on the car today and checked the timing as its never been done in the 8 years Ive owned it... used a strobe and found it to be over 20 degrees btdc!!!! According to book its supposed to be 10, so retarted it but it was a bit lumpy so its now 15, is this OK... It always starts OK and didnt pink even at 20, whats going on?
punkydog
timing question.
« Reply #1 on: May 03, 2007, 09:47:27 PM »
Did you disconnect the vacuum advance?
Brian
fiatfsm
timing question.
« Reply #2 on: May 03, 2007, 10:11:23 PM »
I didnt even notice it :oops: doesnt mention it in manual either.
timing question.
« Reply #3 on: May 03, 2007, 11:46:50 PM »
no vacuum advance on aircooled,its mechanical,and needs lubing from time to time,also,factory sttings are useless when engine has wear,and regonal fuel differences come into the equation, its best to time by ear,advance as much as poss till pinking occures on moderate hill/full throttle,then retard till its JUST gone,then you have optimum power/advance........running retarted does great damage to valves etc,as engine runs smoothly but hot,in extreem cases you can have cherry red exhaust.......i seen that for myself on a landrover S1.and too much advance will rattle your pistons aka pinking/piston slap..........so use your hand for best results :wink:
timing question.
« Reply #4 on: May 04, 2007, 12:13:51 AM »
dont forget to get the points gap correct, this can affect the overal timing!
timing question.
« Reply #5 on: May 04, 2007, 09:26:47 AM »
yes Chris,i forget to metion that  :oops: .....they are by the book,and make sure while your there that the advance mechinisim is free,some times they are solid..........so,take out the distributor and give it a birthday !!... :lol:
fiatfsm
timing question.
« Reply #6 on: May 04, 2007, 09:52:28 AM »
cheers dave, will do that little lube job. :D  points were spot on btw.
