Author Topic: block head!  (Read 8384 times)
block head!
« on: April 25, 2007, 08:38:13 PM »
its amazing what a lick of paint can do!
block head!
« Reply #1 on: April 25, 2007, 09:23:56 PM »
oooh...this looks serious !!.....nice one !!...skimming the head and fitting dead soft copper gasket????.....
block head!
« Reply #2 on: April 26, 2007, 04:04:21 PM »
Looks great, might do this to mine if the head gasket ever goes!
nice one!
block head!
« Reply #3 on: April 26, 2007, 04:58:49 PM »
Quote from: "126dave"
How did you guess? i have a copper one but i did'nt know if it was any better? i got big plans for this engine, i mean i'm not gonna get megga hp out of it but i'm aiming for a 7-8 hp increase, which dont seem alot but when you've only got 26hp to start with, then anything helps right?
block head!
« Reply #4 on: April 26, 2007, 06:05:05 PM »
bang on,anything from 1hp up is good,copper gasket is better for heat transfer,sealing and seating,any engine that suffers from head gasket problems benifits from copper.(we always fitted them to WW2 willys/ford jeeps).....wat you got planned???.....ive allways wondered wat parts from aircooled would fit bis,cams etc,and also in reverse,704cc aircooled ??.....
block head!
« Reply #5 on: April 26, 2007, 09:02:13 PM »
i got loads in the pipe line.I  was just gonna do a rebuild, but i found so may areas where improvment could be made. the first was the lack af air getting in the engine, i'm supprised it did'nt choke to death! so i've opened up the ports a bit and modified the inlet manifold.and with a k&n air filter from my old car grafted on, this should let abit more wind in.
           I've also lightened the flywheel, it seemed ridiculously heavy for an engine that size, so i've had some material shaved off. it still weighs over 5kilos!
            then theres the cooling, which is a very poor design, so i,m fitting, an electric water pump, an electric fuel pump, and fancy ht leads too,
block head!
« Reply #6 on: April 26, 2007, 09:30:15 PM »
a word of warning with the flywheel,its balenced with the crank,so when you lighten it you not only throw it out of balence.....but it cannot be balenced seperatly,nigel told me this and ive since seen it elswhere,thats why all my engine bits are winging there way to uk for dynmic balencing,i have cut loads from my flywheel,(and 2mm from the head)... !!!
block head!
« Reply #7 on: April 26, 2007, 09:58:25 PM »
doh!! wish i'd known that before  :oops:  never mind, i have'nt taken that much off just that 200 tho step at the back
block head!
« Reply #8 on: April 27, 2007, 08:00:49 AM »
while your this far id get the whole lot balenced,i took the whole extra lump off the back as well,and refaced the clutch side.aparently they have to be out of balence to be balenced  :???: to compensate for the crank web and the rotational forces of both pistons decending,in fact im told ,the idea is to move the vibration up beyond 6ooo rpm,where a 126'r on standard crank wont go wothout a bang.
im using JJ engineering in swindon,01793 740169, he did nigels and knows the probs of the twin  :cool: ,
block head!
« Reply #9 on: April 27, 2007, 11:35:09 AM »
I notice you live in Rugby, just down the road we should meet up!
block head!
« Reply #10 on: April 27, 2007, 01:26:35 PM »
blimey gadge you dont hang about  :lol:
looking great!!
wish i could work as fast as that.
block head!
« Reply #11 on: April 27, 2007, 02:25:55 PM »
you could chris, if you wasnt a lazy good for nothing overdraft ridden student.....  :D
block head!
« Reply #12 on: April 27, 2007, 05:03:36 PM »
hahaha, cheaky git!
i wish it wasnt true  :lol:
block head!
« Reply #13 on: April 27, 2007, 05:23:31 PM »
chris, if your a student, then you own the perfect car! :lol:  thanks for all the advice, theres alot of money going into "the little one" so the finished result should be good. i'm going for a retro look, so its getting chome bumpers fitted and losing all that 80's plastic down the sides
block head!
« Reply #14 on: April 27, 2007, 05:25:43 PM »
Quote from: "ciaoflyer"
sounds like a plan i only live in newbold as well
