Author Topic: Emergency flasher relay  (Read 2666 times)
Sam
« on: April 17, 2007, 09:22:37 PM »
I was wondering if anyone can tell me where to find the relay for the emergency lights.  I have a switch on the dash that doesn't do anything.  I am assuming that it is for the emergency lights.  The problem is, according to the manual, the lights were optional.  If someone could send me a picture of the relay so I know what I'm looking for, I would appreciate it.
lilp4130
« Reply #1 on: April 17, 2007, 10:28:14 PM »
i'm not certain but try checking around the fuse box it's in the front boot at the passenger side in my bis i'm pretty sure i saw a few relays round there the other day,check your fuses while your at it!
it's harder than it looks!
Sam
« Reply #2 on: April 18, 2007, 06:10:44 PM »
That's my trouble, I have replaced the only two I can find and nothing seems to have changed.  I wasn't sure if it was hiding on me somewhere out of the way.
lilp4130
« Reply #3 on: April 18, 2007, 08:11:04 PM »
did you check all the fuses??
« Reply #4 on: April 19, 2007, 02:30:09 PM »
if its a bis first of all pull the switch off the dash console (they just pop out)have a look at it to see if it is connected . then take note of the colours of the wiring then trace them back along the loom looking for any abnormalities in the wiring to the fuse box . if nothing is wrong with the wiring then you could have a bad earth somewhere . have a look under the carpet on the passenger side footwell and along the sill as the loom travels back along here and is a trap for water if the windowscreen is leaking. i have found loads of problems have been sorted by repairing wiring in this area. have you got all your indicators working? mick
« Reply #5 on: April 19, 2007, 03:40:26 PM »
switch would be my first port of call.....had loads of greif with them thar crappy switches,clean the spades (steady mick) and use some silicon lube on them......
