Author Topic: upgrade to H4 bulbs  (Read 3617 times)
upgrade to H4 bulbs
« on: April 14, 2007, 07:45:20 PM »
While I had the headlights out to do some paintwork. I modified the units to take H4 bulbs 60w/65w. there are replacements-- 478 but the ones i have found are too high a wattage 130w/90w didn't want to burn the wiring out. first i took the bulb deflector out with a pair of pliers. be careful not to scratch the reflector.
place the bulb into the unit with the thick middle tab facing upwards, mark where the tabs are with a magic marker
file out the three tabs.
fit the bulb using the original clip.
then I cleaned them out, the method I used to clean them is warm soapy water and news paper,first rinse them out then tear the newspaper into about one inch squares (about twenty) put them into the light unit put your thumb over the sidelight hole and pour in some soapy water, then shake for 30 secs pour out, rinse them out well and dry out with a hairdryer, use distilled water if the water is hard and has alot of limescale.
I put in some super white blues
« Last Edit: August 13, 2015, 09:51:42 PM by ChrisRLewis »
upgrade to H4 bulbs
« Reply #1 on: April 15, 2007, 04:22:56 PM »
i went to halfords and found some straight replacements i will try and find the no. nice work though fella.
upgrade to H4 bulbs
« Reply #2 on: April 15, 2007, 06:11:44 PM »
wow, will be making your thread a sticky thats great.
regards
upgrade to H4 bulbs
« Reply #3 on: April 15, 2007, 06:19:38 PM »
my new headies from sausageland had them as standard......not blues tho....very smart pete
upgrade to H4 bulbs
« Reply #4 on: April 15, 2007, 06:44:21 PM »
the reason why i posted this easy mod to convert to P43T bulbs is because there is a better range I.E. blues, purples, xenons, super whites, the list goes on, so you can customize to any colour thats available. but if you want a halogen replacement use a P45T H4 bulb.
upgrade to H4 bulbs
« Reply #5 on: April 15, 2007, 06:47:58 PM »
ah,nice 1,i thought my german headies had it covered but they dont,i like the idea of the blues.....good work pete :cool:
