Author Topic: Thermostat query.....?  (Read 1998 times)
Robbie126
« on: April 13, 2007, 07:29:28 PM »
Hi guys, can anyone tell me more about the thermostat 'conversion' that some people have done to their Bis'. I believe that it is done to help prevent head gasket problems...can anyone shed some more light on this for me?
Cheers for now,
Robbie
 :wink:
Small Fiats...a legal way to put a smile on your face...!
« Reply #1 on: April 13, 2007, 09:08:59 PM »
hi robbie, from what iv seen they seem to be a waste of money. Ive seen head askets go even with these convertions. they are about £120 from ricambio if you are interested. The reason for the conversion is as you probably already know the thermostat housing is at the furthest possible place on the engine from the cylinder head, so open too late.
Some people take the thermostat out, which i dont advise.
The engine doenst need this conversion, IF you use coolant with anti corrosion inhibitor, and clean the thermostat housing out once a year. (the corrosion deposits block the thermostat from opening and block the water jackets too.) the more often you flush the system out the better.
hope this helps a bit.
regards
Robbie126
« Reply #2 on: April 13, 2007, 11:22:12 PM »
Hi Chris, thanks for the heads up on that one I'll get busy on the cleaning out front. I have just done a coolant change but didn't clean out the thermostat housing, I'll drain the coolant down again and have a good poke around inside!
cheers for now,
Robbie.  :)
p.s any sign of my membership bits yet.....?
