Author Topic: HEAD LINING...  (Read 2540 times)
compo1970
HEAD LINING...
« on: April 12, 2007, 10:53:23 PM »
Ive made a start on the interia this week and found that the head lining wont clean up its too far gone.
I started to clean it and it fell to peases
Ive taken it out and the fabric off.
I was just wondering if any one knows where to get hold of some fabric that looks similer?
I dont need very much only the back half of the roof  the front has the sunroof in it.
Also the rear interia panels,Does anybody know if you can get black plastic ones. Ive got the seat belts behind them so they have to be later ones.
Ive only seen bis ones but they are gray i dont really wont to spray them but if i have to i will.
hope some one can answer something on my list.
Cheers compo..Oh and thanks alot mick for the fuel tank im slowly getting there.
philippa
HEAD LINING...
« Reply #1 on: April 13, 2007, 05:59:56 PM »
hi
i had a simlar problem with the lining it just sagged and i took it out and it fell to pieces on me. why dont you try some canvas as that was what i was thinking but not done it yet as it looks ok without.
thanks philippa
HEAD LINING...
« Reply #2 on: April 13, 2007, 06:54:57 PM »
stick a vinyl headlining in that way you can clean the bugger.
compo1970
HEAD LINING...
« Reply #3 on: April 13, 2007, 10:40:47 PM »
Ive thought about vinel, got the missis looking at the fabric wharehouse tomorrow see what she comes back with?
toz
HEAD LINING...
« Reply #4 on: April 13, 2007, 11:40:35 PM »
hi,
ive sprayed my rear pockets black,they look good,all i did was use a plastic cleaner and a scotchbrite(grey),put some plastic primer on them and then some satin black on top,the paint wont flake off if they are keyed up enough,and you could do it cheap as chips
lilp4130
HEAD LINING...
« Reply #5 on: April 15, 2007, 10:55:14 PM »
hey mate i'm plumber by trade mainly industrial and there is a pipe insulation used called armaflex it's available in tubular form and sheet form(for large diameter pipe)in sheet form you can get it in a variety of thickness' and it has a soft feel as it's a kind of high density foam and i think it's only available in black but really you should contact an industrial plumbing or insulation/lagging contractor to get some,cheap as chips and looks/feels great with the added bonus of keeping heat/cold out give it a try i'm gona try get some for mine you'll need an adhesive but from what i've seen you can get it in spray and paint on form just a thought!let me know how you get on!
it's harder than it looks!
compo1970
HEAD LINING...
« Reply #6 on: April 17, 2007, 11:10:04 PM »
thanks for your help i,ll try both of those things.
Ive got engine stripped at the mo got leaking pushrod tubes gonna get the engine sorted first then get the rest of it done.
Want it rite before it goes on the road.
