Author Topic: no spark?  (Read 2126 times)
lilp4130
no spark?
« on: April 11, 2007, 03:11:08 PM »
i was driving my bis today and it started chugging then back fireing and then stopped dead on a hill checked the plugs and they aint sparking could it be the coil??if so where can i get one?(do 126's have a distributor cap i couldnt find it/could it be the points?)
it's harder than it looks!
lilp4130
no spark?
« Reply #1 on: April 11, 2007, 03:55:52 PM »
ok i found out iv'e got no dizzy it uses wasted spark ignition coil,
now i gotta find one!
no spark?
« Reply #2 on: April 11, 2007, 06:20:10 PM »
do a little check first put your car in gear and release the handbrake then watch to see if the points open and close . i had a problem once where my car stopped and the timing chain had broken.  if thats fine check the connection to the battery there is a white connector on the live this sometimes disconnects . if not pm me your address and i can send you a coil . mick
phreak97
  • Niki!
no spark?
« Reply #3 on: July 12, 2007, 01:35:08 PM »
definately check the points.. the same thing happed to me and we had to sleep in the car overnight before we found the problem. it did just what you said too.
phreak97
