Author Topic: engine swaps?  (Read 2178 times)
lilp4130
engine swaps?
« on: March 29, 2007, 12:53:24 PM »
i've been researching cinquecento/seicento sporting (fire) engine & gearbox swaps and am pretty confussed at this stage if this is practical or not also if the engine was put in back to front(as in opposite the way it was intended)does this mean your shift pattern for the gears is all reversed??
it's harder than it looks!
hudsonhenry
    • http://www.retro500.com
engine swaps?
« Reply #1 on: March 29, 2007, 01:05:19 PM »
If you want to use the cinquecento/seicento engine and gearbox you will loose the rear seats. Basicly the whole assembly moves from the front to the middle without a change in orientation.
If you want to use the 126 gearbox (and keep your back seats) then the engine is turned 90 degrees (from transverse to in-line). The engine spins in the right direction so all you need is an adaptor plate and some way of mounting the bigger engine.
For the latter have a look at my car at www.retro500.com - gallery - nigels 1108, its a 500 but the principal is exactly the same for the 126.
Hope this helps
Nigel
