Author Topic: does anyone know how to remove the front windows(bis)??  (Read 4652 times)
lilp4130
« on: March 28, 2007, 11:21:35 AM »
has anyone tried putting tints in their windows??christ it tries ur patience!i bought a light smoke tint and spent all day yesterday trying and only one window looks good i also ran out of tint,balls!the rear driverside window looks great because i removed it and could do it properly but the front ones look poo!does anyone know how to remove the front windows(bis)??i also need to remove the small triangular ones too,any help would be reall appreciated!
it's harder than it looks!
« Reply #1 on: March 28, 2007, 12:22:10 PM »
best bet is get on e bay and buy an old haines manual . it doesnt cover your engine but will tell you how to remove all the bits like windows trim excetera, and it will only cost pennies.
lilp4130
« Reply #2 on: March 28, 2007, 01:28:56 PM »
thanks for the reply!i tried grtting them out myself but was afraid i'd brake them!!
« Reply #3 on: March 28, 2007, 03:11:16 PM »
yer, try not to break them theyre a pain to find.
regards
« Reply #4 on: March 28, 2007, 05:21:29 PM »
to be honest they are quite easy to remove however you must remove screws that are rusted 99% of the time and venture into the internals of the door  being carefull not to break anything .
lilp4130
« Reply #5 on: March 28, 2007, 06:02:26 PM »
great!i've taken off the door panels and behind the plastic sheeting it seems its just sitting in the runner held in by rubber?also is there a screw in the lower pivot of the triangular windows?
toz
windows
« Reply #6 on: March 28, 2007, 07:41:57 PM »
hi,i have removed all the windows from my air cooled,they are the same and are an absolute pain in the arse,i had to remove the traingular window to even get the drop glass out,basically you have to take off all the trim that always bend inside and outside,try to keep an eye out for all those flying retaing clips,
from memory i had to unscrew everything even the drop glass away from its main runners and where the cable holds it at the bottom,you have to wind the glass down to the bottom unscrew most things take all the bits out like the runners for ease of access,
remember the triangular glass has to come out first,it is not difficult just alot off wobbling around,you shouldnt break any glass at all i found theres more tension on the glass trying to pull it out from the inside,found it much easier to take it out from exterior side.and then at last she is free :)
i removed all my doors as found it so much easier but they are a 2 man job to put back on unless you dont want any paint left at the front off the doors and the backs off the wings :wink:
hope this helps i dont want to keep going on as iam going to fall into a coma just reading it myself, :lol:
« Reply #7 on: March 28, 2007, 07:48:43 PM »
i agree......,total pain in the arse,probably why the poles stopped making the things........the bloke who could do it died,at the very least thats why they changed to full windows on the last ones.........id rather buy a new door than venture ino the intrnals of a 126 door :roll:
toz
« Reply #8 on: March 28, 2007, 08:00:17 PM »
:idea: this is probably one of the most stupid things i will say in my life but most motor companys scrimp on new bits for there cars,fiat carried on makeing the 126 in poland while we got the cinq,i have noticed that the late polish aircooled wore the cinq mirrors when they had full door glasses instead of 2 pieces(drop and triangular),couldnt this probably be the cinq door glass???????????
« Reply #9 on: March 28, 2007, 08:31:29 PM »
possibly,the late cars did cinq instruments etc...............in a previous life i used to make stuff,we always used as much as poss from previous models for the new release's...doubt that fiat would be different from that.
lilp4130
« Reply #10 on: March 29, 2007, 11:31:48 AM »
thanks for all your help guys i have a new set of tints ordered they should be arriving tomorrow so i'l spend the day with my windows and let you know how i get on,all the pointers are much appreciated,i might even be able to add some pictures as i progress with my project!
« Reply #11 on: March 29, 2007, 06:14:23 PM »
I took mine out with no probs, About 30 mins to get the whole lot out, putting it back in is another thing though!
lilp4130
sorted
« Reply #12 on: April 05, 2007, 09:07:14 PM »
got the tins in {and the windows out!}uploaded pics too!
thanks for all your help!
