Author Topic: engine questions  (Read 2430 times)
Marek
engine questions
« on: March 25, 2007, 08:10:54 AM »
heya,
i've found someone on ebay selling a 126 aircooled engine minus the head for $20 in .au..
from what i've discovered the panda 30? heads bolt straight on..
http://cgi.ebay.com.au/Fiat-500-126-Tuning-Panda-30-Zylinderkopf_W0QQitemZ200091114409QQcategoryZ9903QQrdZ1QQcmdZViewItem
is this a worth while thing to do?
auction ends in less than 14 hours :(
1990 Nissan 180sx sr20det - 250hp
1990 FSM Niki aircooled 650cc - 25hp
engine questions
« Reply #1 on: March 25, 2007, 09:59:31 AM »
the panda does indeed bolt on,but you need to modify the tin work to fit it back,and two engine studs need extending,and one shortening.
also you will need a new inlet manifold to fit the new carb of your choice,then to get the best from the new carb/head etc you need sport exhaust and a fast road cam,also you should skim the head to get higher comp ratio..................then you need an oil cooler kit,lightened flywheel  and full engine balence really.............. :cool: if you go ahead with this drop me a line ive done it to mine,and can help you with the problems that crop up
a well ported and bigger valved 650 head is about equal to the twin port panda head im told......
