the stud pattern is non to clever either.......if the guy in the factory didnt care,or the last clot who did the head gasket didnt,(the correct thick washers,and clean threads are crucial to spread the load )it will go again,but cool is good,and re torqued head bolts are added insurance(loosen half turn when cold,then re torque).
also,ive noticed thet studs can be badly corroded in engines with the wrong coolent,this must cause them to stretch/relax and let the head loose???................................. :?:
