Author Topic: aircooled temp gauge  (Read 2233 times)
paulisa
« on: March 01, 2007, 08:23:18 PM »
well after i fitted my new dash from a bis i thought i would get a temp sender from a bis and weld a boss into the sump so the sender is in the oil i will then wire it to the bis gauge so i should then know when my motor is getting hot will let you all know how it works when done
« Reply #1 on: March 01, 2007, 09:19:54 PM »
sounds a good plan.......i might try this myself........at the moment i watch my pressure gauge to work out engine temp.....i was thinking of a dry sender attatched to the block/cylinder head,but that would give localised temp readings......this oil based idea is much better........... :D
paulisa
« Reply #2 on: March 01, 2007, 09:23:02 PM »
the other option for a temp gauge is i saw a aftermarket temp gauge for a vw beetle and the sender was a copper ring that went under a spark plug so you got the cyl head temp but i like the oil temp idea
