Author Topic: Radio draining battery  (Read 2631 times)
nathan126
« on: February 23, 2007, 05:48:34 PM »
Hi guys, i recently fitted a cd player and speakers to my BIS and its has been draining my battery.
Could this be a fault with the electrical system or should i just fit a kill-switch to the live feed?
....Is this common with fitting a CD player to a 126?  :?:   :cool:
« Reply #1 on: February 23, 2007, 06:38:20 PM »
You should have two +'s on your radio, one for main feed (direct to battery) this stores clock time, alarm, maybe a glow to the on/off switch.  The other lead is a switchable +, wire this to ignition so it only works when the ignition is on.
hope this helps?
« Reply #2 on: February 23, 2007, 06:43:20 PM »
hope this helps?
nathan126
« Reply #3 on: February 23, 2007, 06:56:49 PM »
Yeah probably...
I seem to only have one positive feed with two short leads separating from that. So im either going to extend that to the ignition or fit a kill-switch to the + so that it the power can be manually switched on or off from the battery.
       Thanks  :cool:
