remove plastic tray around handbrake area,lift carpets out the way,undo the 10mm nuts that hold the forward heater duct panel in place,this exposes the cble end,remove split pin, and slip the cable end off the throttle bar,then undo it at the carb end,then from inside car pull the cable out.........................blast some wd40 down the now empty cable conduit from both ends........than put it all back again...........when you put tjhe cable back.it might stick half way down as it enters the flexi bit at the back,do not force,rotate it gently while pushing gently,it will feed itself in.
TIP,while you ghave gone this far,undo the 2 10mm screws that hold the throttle pedal assembly to the floor....remove and lube thoroughly.
i drill a hole in mine so i can drop some oil in from time to time......
