Author Topic: Bloody Clutch!!!  (Read 2794 times)
bigjimmer
Bloody Clutch!!!
« on: February 21, 2007, 04:44:43 PM »
How do all,
A friend recently put a new clutch in my 126. When i drive it however, it is grinding in 3rd (no chance of it going in) unless i drop all the revs off first. The cable was loose when i got it back but i have tightened it a little and it is better now, could it be that it just needs tightening a little more? I noticed something about gear alignment in another forum i am hoping it has nothing to do with that. I have no garage and hate cold weather, mores the point, i have few tools due to no garage and hating the cold.
Any ideas? I may put the car in one of those stupid wheelie bins that the council have given us.
Bloody Clutch!!!
« Reply #1 on: February 21, 2007, 07:02:04 PM »
stop the talk of dumping your 126 in a wheelie bin! or we'll send the 126 mob round  :lol:
just sounds like clutch cable needs adjusting mate, ive had the same problem before, i believe the clutch pedal should sit 2cm below the brake pedal.
The cluitch cables can strectch and fray, so might been a new one.
but i dont think its anything serious.
Bloody Clutch!!!
« Reply #2 on: February 21, 2007, 09:14:07 PM »
here is a guide for clutch adjustment
Dragonstone
The Basics of Clutch Operation
« Reply #3 on: February 23, 2007, 02:31:52 PM »
If you've ever driven a vehicle with a manual transmission, you know how to depress the clutch, select a gear, and release the clutch while applying power to get the car to move. But what really happens when you depress and release the clutch? Let's get to the bottom of that question where is it.
you will find the clutch inside here.number 1 .above..this is on the side of your engine to the right as you look at it with the hood-up...
In its simplest form, the clutch allows engine power to be applied gradually when a vehicle is starting out and interrupts power to avoid gear crunching when shifting. Engaging the clutch allows power to transfer from the engine to the transmission and drive wheels. Disengaging the clutch stops the power transfer and allows the engine to continue turning without force to the drive wheels. To understand how a clutch works, we first need to understand who the players are and how the whole shebang works. So let's look at the basic components: the flywheel, clutch disk, pressure plate, throw-out bearing and linkage.
Photos removed as they are not 126's
A large steel or aluminum "disc," the flywheel is bolted to the crankshaft of the engine. The flywheel does many things - acts as balancer for the engine, dampens engine vibrations caused by the firing of each cylinder, and provides a smooth-machined "friction" surface that the clutch can contact. But its main function is to transfer engine torque from the engine to the transmission. The flywheel also has teeth along the circumference, allowing the starter motor to contact when turning the engine over.
The clutch disc is basically a steel plate, item number 2 above photo covered with a frictional material that goes between the flywheel and the pressure plate. In the center of the disc is the hub,item number 1 above which is designed to fit over the spines of the input shaft of the transmission. When the clutch is engaged, the disc is "squeezed" between the flywheel and pressure plate, and power from the engine is transmitted by the disc's hub to the input shaft of the transmission.
In layman's terms, a pressure plate is a spring-loaded "clamp," which is bolted to the flywheel. It includes a sheet metal cover, heavy release springs, a metal pressure ring that provides a friction surface for the clutch disc, a thrust ring or fingers for the release bearing, and release levers. The release levers lighten the holding force of the springs when the clutch is disengaged. The springs used on our pressure plates are of a diaphragm-type,
The "throw-out bearing"item number 3 above photo is the heart of clutch operation. When the clutch pedal is depressed, the throw-out bearing moves toward the flywheel, pushing in the pressure plate's release fingers and moving the pressure plate fingers or levers against pressure plate spring force. This action moves the pressure plate away from the clutch disc, thus interrupting power flow.
Mounted on an iron casting called a hub, the throw-out bearing slides on a hollow shaft at the front of the transmission housing. The clutch fork and connecting linkage convert the movement of the clutch pedal to the back and forth movement of the clutch throw-out bearing. To disengage the clutch, the release bearing is moved toward the flywheel by the clutch fork. As the bearing contacts the pressure plate's release fingers, it begins to rotate with the pressure plate assembly.
The release bearing continues to move forward and pressure on the release levers or fingers causes the force of the pressure plate's spring to move away from the clutch disc. To engage the clutch, the clutch pedal is released and the release bearing moves away from the pressure plate. This action allows the pressure plate's springs to force against the clutch disc, engaging the clutch to the flywheel. Once the clutch is fully engaged, the release bearing is normally stationary and does not rotate with the pressure plate.
Now that we have the parts, how do they all work together? Thankfully, it's not rocket science.
A cable-type clutch linkage is simple, lightweight and is the most common linkage on newer cars today this is what we have. Normally, a cable connects the pivot of the clutch pedal directly to the release fork. This simple design is flexible, compact, and eliminates nearly all of the wearing pivot points found in a shaft and lever linkage. There is one downside to this type of setup: cables will gradually stretch and can break due to excessive wear and electrolysis.
On a typical installation, one end of the cable is connected to the clutch pedal and a spring is attached to the pedal assembly to keep the pedal in the "up" position. The other end of the cable is connected to the clutch release fork with a fitting that allows for free-play adjustments. When the clutch pedal is depressed, the cable pulls the clutch fork, causing the release bearing to move forward against the pressure plate.
Now that you know what happens when you depress the clutch pedal, what are the warning signs that a clutch needs adjustment or replacement? While most new car clutch linkages are self-adjusting, On the Cinquecento this is not the case but there are some telltale signs that will tell you if adjustment is needed. For instance, if the clutch engages and disengages close to the floorboard or the transmission "grinds" when shifting, your clutch may need attention.
Does the clutch pedal move easily, but the transmission will not go into gear? More than likely, the clutch linkage has become disconnected or a clutch cable has snapped. If the clutch slips (doesn't fully engage), the linkage could be grossly out of adjustment, or the clutch disk could be worn to the point of replacement. Clutch "chatter" is often caused by an overheated clutch (normally from "slipping" the clutch when starting on an incline) or from oil on the clutch disk. In either case, the clutch must be replaced. No matter what symptoms your vehicle may have, always consult with a certified mechanic to diagnose the problem properly.
Although it may seem like there's not much to getting your car in and out of gear, a lot is going on behind the scenes each time you depress the clutch pedal. Now you have something to think about each time you're faced with rush-hour traffic.
This is a sticky taken from my site at cento-rebels.com please feel free to use and modify in any way for Fiat 126 use Dragonstone
bigjimmer
Bloody Clutch!!!
« Reply #4 on: February 26, 2007, 08:41:13 AM »
How do all,
I have taken the car to my friendly mechanic who revealed the the gear linkage was loose (box to stick). I have decided against putting it in the wheelie bin for now so i would appreciate it if you would call off the mob. She's purring like a kitten with a cream flavoured botty, and i now only have the lights left to sort out (strange behaviour).
Thanks as ever.
Jimmy
