Author Topic: Power Brakes  (Read 5635 times)
Power Brakes
« on: February 20, 2007, 11:03:47 PM »
Just an idea, for anyone who thought of fitting servo assisted brakes,
suggested parts, small diameter servo possibly nissan micra mk1. vacuum pump off peugeot 205 diesel. but best get your tape measure out and go down to the local wreckers. any other donor parts or suggestions please post.
Power Brakes
« Reply #1 on: February 21, 2007, 08:25:28 AM »
mmnn.nice,what about the remote plumbed in ones from MG 1100's etc,i used to fit those to morris minors.means you keep the original master cylinder..........just a thought. :D
but to be honest a good drum set up or even better a disc conversion doesnt need a servo?.my disc setup has to be carefully managed in the wet as it is. :shock: .........................i could do with a brake bias knob in the cabin...........then i could also put full bias to the front for those traffic light burn outs eh???? :twisted:
hudsonhenry
    • http://www.retro500.com
Power Brakes
« Reply #2 on: February 21, 2007, 10:36:07 AM »
Its not worth putting a servo on. With the right front disk conversion the brakes are beautifully balanced, you get plenty of feel through the pedal and can slam them on hard as you like without getting them locking up, a servo will feel wooden by comparison and with such a light car and no ABS you are likely to just lock up and slide.
I have a motorcycle with a servo, its the worst thing about it, too much initial bite then no feel, would have been OK if I had gone with the ABS I suppose.
ger
    • http://www.dropshots.com/ger
Power Brakes
« Reply #3 on: February 21, 2007, 10:49:46 AM »
I fitted a lockheed remote servo to my little Rod.....Improved the brakes but with  softer pedal and more travel...Its an all disk setup so I had a lot of messing around getting the correct ratios, (pedal, master cylinder, servo)
You need a decent vacuum to power the servo, which I doubt the 500 engine would deliver. Seperate pump would likley be required.
Gerry
Gerry
(Near Glasgow, Scotland)
(500 all done MOT'd !)
Power Brakes
« Reply #4 on: February 21, 2007, 10:55:10 AM »
i agree nigel,but mine are prone to locking up the front in the wet,a drain cover is all the excuss they need...........but they really are very good tho.its prob me just pushing too hard ...again.... :roll:
also as ive said elsewhere,my tyres are not top branded items
Power Brakes
« Reply #5 on: February 21, 2007, 11:13:15 AM »
Great idea, but like nigel said for a disc set up it should'nt be needed.
But for a standard drum set up it should improve things drastically!
Power Brakes
« Reply #6 on: February 21, 2007, 11:29:16 AM »
just looked at our ford transit, the alternator has the brake vacuum pump on the back, by swopping the front pulley should make it easy to fit onto a bis, and as cars said would make a vast improvement to the drum brake setup.
hudsonhenry
Power Brakes
« Reply #7 on: February 21, 2007, 01:49:43 PM »
Go for it, if you have the bits to hand, it can't hurt to try. If it works well you could be pioneering a new mod for the 126/500 that is more cost effective than a disk conversion, keep us informed of your progress
Nigel
Power Brakes
« Reply #8 on: March 12, 2007, 09:57:55 AM »
I am about to scrap a Peugeot 405 GRDT.
Think I'll whip the altonator off and try it too.
Power Brakes
« Reply #9 on: March 12, 2007, 06:24:54 PM »
works well on ferrari's so why not a baby fiat.
Bruce
Power Brakes
« Reply #10 on: March 12, 2007, 08:09:25 PM »
the main problem i can see with this is the position of the vacuum pum/manifold relative to the brake servo; my old Merc had vacumn operated cetral locking and it allways leaked, and as far as i can remeber my X1/9 did not even have servo assisted brakes, possibley due to the position of the engine relative to the brake master cylinder
Power Brakes
« Reply #11 on: March 12, 2007, 09:03:00 PM »
on my pontiac fiero (mid engine) the system is a solid stainlees steel pipe running through the transmission tunnel from the brake servo at the front to the engine inlet manifold at the rear using two rubber pipe joints, i was thinking if i did this mod' of using copper pipe (plumbing) for this, then two rubber pipe joints one on the vacume pump and one on the servo, i know what you mean about central locking but this is'nt as complicated i had an audi with that system but never had any problems with it, besides this is running one pipe with two joints so should'nt be a problem
Bruce
Power Brakes
« Reply #12 on: March 12, 2007, 10:08:19 PM »
I guess that could work.
