well,that'l be the splines then mick,easy to do if the RIGHT bit is knackered,drop the halfshaft (four bolts at the wheel end,catch the little anti rattle spring that will fall out) out on the spinning side........there is a circlip on the end of drive shaft,pull that off and the cast outer drive flange will come off,with its rubber boot,you have to now prey that thats the knackered bit and not the drive shaft splines.
if so, replacement is the reverse of removal...........i have good ones here on my rebuilt box if you need one asap....... :wink:
