Author Topic: unleaded petrol  (Read 9161 times)
paulisa
unleaded petrol
« on: February 14, 2007, 08:24:20 AM »
hi guys will my 126 fsm run on unleaded without damage or should i be using lead substitute it does get driven hard all the time but has lost a bit of power lately
unleaded petrol
« Reply #1 on: February 14, 2007, 08:32:33 AM »
If it's a Bis it will run on unleaded, however if it's aircooled you will need to a a substitute but I am not sure about late aircooled's, there are many posts on this subject do a search
good luck!
unleaded petrol
« Reply #2 on: February 14, 2007, 04:33:35 PM »
all air cooled engines need a lead replacement unless you have converted it to run on unleaded .
paulisa
unleaded petrol
« Reply #3 on: February 14, 2007, 04:43:44 PM »
thanks guys is there a best option on the substitute ie shell / millers etc
best go re set the tappets it seams to be popping on the overrun a lot now and bit harder to start
unleaded petrol
« Reply #4 on: February 14, 2007, 04:45:47 PM »
thats how mine started to go as my head gasket failed, oops
i think its castrol? but its deffinately called "valvemaster" comes as lead replacement or lead replacement with octane boost , from halfords.
price is from about £10. to £12.
paulisa
unleaded petrol
« Reply #5 on: February 14, 2007, 04:47:49 PM »
just done the head gasket not so long ago and it was going really well just seams to be losing power at the moment turbo needed lol
unleaded petrol
« Reply #6 on: February 14, 2007, 04:49:33 PM »
try re nipping your headbolts , do you drive your car hard?
paulisa
unleaded petrol
« Reply #7 on: February 14, 2007, 04:52:57 PM »
yes its driven hard only 2 positions on the throttle tickover and flat to the floor i have redone the head bolts after the first few hundred miles will run through the tappets in the morning see what  they are like
unleaded petrol
« Reply #8 on: February 14, 2007, 05:03:28 PM »
i use super unleaded and castrol valvemaster plus,if i dont it pinks..........
paulisa
unleaded petrol
« Reply #9 on: February 14, 2007, 05:33:33 PM »
just being out and bought a bottle of valvemaster + will do the tappets in the morning see if it improves
unleaded petrol
« Reply #10 on: February 14, 2007, 06:09:45 PM »
its good to see you drive your 126 in "all or nothing " fashion. enjoy . i have done my head gasket twice now in the space of about 4 months . i cant adress my driving technique so i have now bought loads of head gaskets ! i have two heads and will rotate them in between skimming!
the valvemaster will stop the pinking my car was terrible without it no matter what adjustments i made . mick
unleaded petrol
« Reply #11 on: February 14, 2007, 06:21:09 PM »
i too am a follower of the pedal to the metal school of 126 driving......perhaps we should form an offshoot of this club..........the ''f***** flat out fiat drivers''?
unleaded petrol
« Reply #12 on: February 14, 2007, 06:25:25 PM »
now now calm down , don t go all renegade on us, you will only upset the waxoil and carpet brigade..... :D
unleaded petrol
« Reply #13 on: February 14, 2007, 07:26:39 PM »
lol im creased up with laughter here,  :lol:
i must admit though i dont drive my 126 slowly, its like being told to drive a go kart around a track slowly, any other car i will happily drive nicely, but stick me in a 126, youve then got me doing Scanadanvian flicks and hill jumping!  :lol:
i think we should get down to an outdoor go kart track in summer, see who really does have the skills....no mick its not a chance for you to break my neck  :lol:
unleaded petrol
« Reply #14 on: February 14, 2007, 07:43:41 PM »
im gona admit something here.........every week i check/reset the throttle cable/points/plug gaps on buzzbomb..........helper in driver seat planting pedal hard down,,,,me with engineers mirror and torch checking throttle/venturi's opening and maybe adjusting linkage to get 'full bore' setting.................then road test to see if i can advance the ig timing a smidge.................i do use more valvemaster than spec....the more you use the more advanced you can go..........
