Author Topic: Disc brakes  (Read 21069 times)
hudsonhenry
    • http://www.retro500.com
Disc brakes
« Reply #30 on: February 22, 2007, 09:51:31 AM »
Quote from: "nitro_trs"
Car is almost ready. I think, that possible receipt will be to saturday.
Engine 1.2 8V 75 PS :D
Looks good, did you do anything to the gearbox to make it stronger? I see that you have gound away some of the inner bellhousing on the gearbox, does this now clear the stock 75 flywheel? on my conversion I used a Fire 1000 flywheel and clutch as its slightly smaller.
Nigel
www.retro500.com
nitro_trs
    • http://www.trs-racing.pl
Disc brakes
« Reply #31 on: February 23, 2007, 11:59:11 AM »
I remove inner bellhousing on the gearbox for bring closer engine to gearbox. Flywheel is modificated and remaked from original flywheel. Cluth disk and cluth plate are from Cinquecento 900.
TRS SWAP CENTER  www.trs-racing.pl
Disc brakes
« Reply #32 on: March 21, 2007, 09:23:51 AM »
This is the exact disc brake kit that I have, unfortunately, I had to do a little grinding of the hubs to get the discs to fit.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290091184610
What else will I need to actually fit the brakes to the car? Will i need to buy new flexi pipes? (what type and where from?) Can anyone tell me what car these calipers have come off. I think it may be a fiat uno or panda. Also, where exactly do the pipes go? There are two holes per caliper.
Thany yous
Disc brakes
« Reply #33 on: March 21, 2007, 03:06:36 PM »
you have a big hole on top thats for the pipe connection , then a smaller hole next to it that is the bleed valve and on the front usually is another hole that is for a pipe clamp.they look pretty much like what ive got and they are for a polski fiat( 125?) the old yugo/lada thingy.
Disc brakes
« Reply #34 on: March 21, 2007, 08:04:00 PM »
Cheers Mick,
What will I need to buy in terms of the pipes? Is there a standard type, or will I have to order some specialist 500/126 one?
Disc brakes
« Reply #35 on: March 21, 2007, 08:20:33 PM »
hi dom,these are different calipers to mine,mine are ford items,and the normal 126 flexis fitted fine,did your kit not come with bleed /banjo connections??.
the 126 hubs seem to come in slightly diff sizes,thats why you had to grind yours a little,make sure the disc fits flat to the hub surface before tightning the wheels up,the discs WILL destort if not,i gave my hubs a slight chamfer then lapped them to the discs with some coarse grinding paste.my kit had already been botched,(hubs butchered) and i had to re seat the replacement discs on my slightly gound down original hubs,also,the new back plates touched the gaiters on the track rod ends,check yours are ok,i had to grind a small amount of steel away for clearence.....OH,and check the caliper fixing bolts are not too long,mine were,and were going to gouge big troughs in the new discs................................................. :evil:
Disc brakes
« Reply #36 on: March 22, 2007, 03:57:07 PM »
Good stuff.
Are the standard 500 flexipipes already on, likely to fit the new calipers? Im not sure what flexis to get if thay dont, as i'm not sure if modern pipes have the same connections?
Disc brakes
« Reply #37 on: March 22, 2007, 04:53:37 PM »
they should fit ok theres only one way to see and give them a try , put them on and get your brother to lay under the car looking to see if they leak. press the brakes on and off plenty of times , if he comes up covered in fluid sreaming he cant see it means they need replacing if he just stays laying there quietly he s gone to sleep cos they are fine but boring.
Disc brakes
« Reply #38 on: March 22, 2007, 06:06:17 PM »
dom,try asking the supplier of your kit for the correct parts,126 flexis have a banjo style at the wheel cylinder end.and dont forget the soft copper washers eh??.gota dash,first coat of repsol orange going on my wheels tonight..............
disc project
« Reply #39 on: April 11, 2007, 12:52:34 AM »
Hi.
I'm on the way to getting front discs on my 500 (Steering rack conversion is also on its way, may as well do a few things while I'm down there!)
I've gone for the Fiat 125 route as I'd rather have the 227mm discs than the 240, mainly because I've already bought them!
I found a set of Fiat X1/9 front cailpers with mounting rails for a reasonable price so that will be my starting point. I think I'll make the plate up myself (anyone know how thick the adapter plate should be?) I've most of the tools here, and a steel yard only down the road.
While cross referencing the discs I came across ATE Brakes http://www.conti-online.com/generator/www/com/en/ate/ate/general/home/index_en.html
Very good for finding comapritive donors. I spotted theat the Cinq and Seicento match the centre diameter of the of the hub 59mm with 123mm inner disc diameter so no need to re shape the hub and a snug fit . The Fiat 125 is 62mm hub with 117mm inner disc diameter. This means the hub is a very loose fit, but the inner disc is a little too snug which allows disc/hub alignment once the hub is trimmed a little.
Lots of info on this site as they give dimensions most sites leave out. More importantly it gives a list as long as your arm of related vehicles which is very handy for the odd ebay purchase!
Curently overhauling the kingpins to go with the new front bearings,
to go with the disc conversions,
to go with the steering rack conversion.
Who said men can't multitask!
Disc brakes
« Reply #40 on: April 11, 2007, 01:09:12 AM »
blimey youve been busy mate
everyone at this point seems to have their own method of going about geting disc breaks,
x1/9 calipers must be same/similar to the uno ones which are commonly used?
regards
Disc brakes
« Reply #41 on: April 11, 2007, 10:55:46 AM »
I still have my disc kit sitting in the front room at home. Working on fixing the old drums and getting the car back on the road before I start meddling with new wheels and the discs. Been messing it up far too often, so right now I just want to drive!
When is the next meeting in the Londonish area scheduled for?
