Author Topic: i brought a fiat panda :)  (Read 6059 times)
nrg19uk
« on: June 30, 2005, 01:31:16 PM »
hi all i brought a fiat panda for 100 quid off ebay, i got it home and realised that its dripping oil on my drive from the rubber sill round the drive shaft any ideas?
Neil gargaro
« Reply #1 on: June 30, 2005, 03:04:46 PM »
Sounds like the drive shaft oil seal is leaking where the driveshaft enters the gearbox.
Usually an easy job, drain gearbox oil, remove the driveshaft, which is the tricky bit! And prise out the old seal and replace with a new one, should only cost you a pound or two for a new seal. Re-fit the drive shaft and replace oil.
Job done!
What year and engine is it? I will check my manual to see if there are any other procedures I missed out on?
nrg19uk
car
« Reply #2 on: June 30, 2005, 06:22:57 PM »
its 750 panda L jreg 91 i think
thanks for your reply
Neil gargaro
fiatfsm
« Reply #3 on: June 30, 2005, 08:40:52 PM »
The driveshaft oil seal on Pandas is actually part of the driveshaft boot, its a nylon bearing, they cost around ?7 from Fiat dealers. You have to replace the whole boot.
green-fly
« Reply #4 on: June 30, 2005, 10:06:27 PM »
make sure you can get the gearbox oil filler plug off first before draining out your oil !!!
 (thought i better mention it before someone else does! :lol: )
good luck!
nrg19uk
draining oil
« Reply #5 on: July 01, 2005, 12:47:37 PM »
well i dnt need to worry about draining the oil coz gravity is doing that for me all over my friends drive :P i hope i can get the plug out lol has anyone got a panda manual on disc?
Neil gargaro
« Reply #6 on: July 01, 2005, 03:48:14 PM »
pm sent!
cars
 :D
