Author Topic: Chrome bumpers on a bis?  (Read 5563 times)
punkydog
« on: January 17, 2007, 06:43:43 PM »
I was stripping down my daughters Bis today for a respray and a thought occurred to me whether it would be possible to give it a more retro look using the bumpers and window surounds from an old air cooled and doing away with all the black placcy scuff strips etc. which despite countless re-blackings remain grey.
Has anyone done this? I can see that the rear side bumper support holes would need filling along with the holes in the doors etc.
Not having an old ac 126 to hand I am not sure if the front and rear panels differ between the two models.
Brian
« Reply #1 on: January 17, 2007, 07:01:10 PM »
hi,there are other threads already covering this,but yes,the bumpers etc will fit no problem,other guys have done it and im sure you'll get lots of replies.
they look loads better with smaller bumpers,and the side trims removed and welded/filled.
check out my late rubber bumper aircooled in the garage section with the body mods done,although i have not replaced with chrome yet. :cool:
punkydog
« Reply #2 on: January 17, 2007, 07:23:33 PM »
Yes, I was aware that the swap was OK on the AC models but I was unsure about putting them on a bis. The front panel has quite a few dimples and things to accommodate the huge bumpers. I assume that the front side window surround is transferable what about the windscreen surround and the rear window ? Ditto the door handles. Do chrome bumper ACs have a gutter trim? Has anyone got the parts I need?
Brian
« Reply #3 on: January 17, 2007, 07:31:28 PM »
yes,the front panels of late a/c and bis have the same dimples as you mention.........
you need to get a polish contact for all the chrome stuff you need,there are a few guys on here with the right connections!!!
good luck
dave  :wink:
Tomasz
« Reply #4 on: January 18, 2007, 12:02:49 AM »
My a/c had complete plastic trim and i took it all off.  The holes on the chrome bumpers and the holes in the body were not quite in line but this is no big problem and filling the holes in the side is easy 'cause its easy to access the holes from the inside.  The back bumper holes were in line.  It looks so much better in my opinion.  I also got chrome wiper blades but have not got the door handles yet.
Think i got my bumpers from Germany off ebay but you can get them and the fittings from www.fiat500126.de.  Worth checking ebay and searching within europe first though.
punkydog
« Reply #5 on: January 18, 2007, 07:08:20 AM »
The chrome bumpers are cheaper than the plastic, 39.5 euros plus tax and shipping, from Axel and they have all the fittings too. To get an old bumper chromed costs £100. They also have the stainless front window frames. I was going to replace the black ones anyway.
I will probably be taking the front screen out to get at the rust in the lower corners, I think it is bonded on a bis, does anyone know if will the older screen rubber will fit with the chromey locking strip?
Where is the rear number plate light located on chrome bumper models?
Brian
kurt green
« Reply #6 on: January 20, 2007, 11:17:48 PM »
Hi Brian
Nice to see you doing all this work on my old BIS, maybe you would post a photo of the finished product onto the website?
« Reply #7 on: January 23, 2007, 06:21:55 PM »
Heres my Bis.  My bumpers are mini ones moded to fit!  I would like some original bumpers though if anyone has any for sale.
punkydog
« Reply #8 on: January 23, 2007, 07:35:50 PM »
If it looks OK Kurt I will post pics.
Ordered all the bumpers and brackets plus alloy window frames from Axel. If past experience is anthing to go by I will get one bumper bolt and an unspecified wait for the rest. Chrome airscoops would be nice, I need to find a friendly metallising firm. The front screen will be coming out, I have just cut the rubber away to get at the rust in the corners, I intend to use a screen rubber with a chromey plastic infill. Reversing and fog lights , gutter trim, mirrors and wipers aren't a problem not sure what to do about the rear number plate light maybe an mg one. I quite like the idea of steel wheels with with chrome hubcaps, did Ladas or something use Fiat 13" wheels with caps? Perhaps too wide. Insurance too loaded for alloys - yawn anyway.
I discovered that almost any old key would open the drivers door so those units need replacing, I will try and get the early shiny type. All this takes me back to my lambretta and vespa days.
Brian
« Reply #9 on: January 24, 2007, 08:39:23 AM »
hi punkydog ive done the whole removal of plastic trim and fitting of chrome bumpers and i can say its a alot of work but worth it heres a few pics at various stages (in no particular order....top one iis the latest...)
 if you have any questions on how to give me a shout... hope you like welding!!!!
