Fiat 126 Chat
PLEASE HELP! points
Pages: [
Topic: PLEASE HELP! points (Read 2016 times)
mattlucas
Member
PLEASE HELP! points
on:
January 15, 2007, 08:14:40 PM »
ok i ve tried a new carb and rus for about 10miles later cut out and wouldnt start again a freind of mine looked at it and said it could be the points we had a look and unless its diffrent to any other cars then they need ajustinddoes any body know how to do this any sugestions greatly recived many thanks
matt
Utterly-Butterly
Member
PLEASE HELP! points
Reply #1 on:
January 17, 2007, 08:21:00 PM »
Just fit a new set in, not worth the messing around with existing points.
If BIS and if using M. Marelli distributor set them at 0.37 - 0.43
If BIS and if using Zelmot distributor set them at 0.47 - 0.55
Regards
Steve
phreak97
Niki!
PLEASE HELP! points
Reply #2 on:
July 12, 2007, 01:58:35 PM »
to get you out of the poo you can bend them apart and the car will run, probably a bit rough, but it will run. otherwise i thought there was a screw for adjustment?
phreak97
Pages: [
Fiat 126 Chat
PLEASE HELP! points
