Author Topic: Alloy Wheels  (Read 7821 times)
Alloy Wheels
« on: January 12, 2007, 05:50:19 PM »
Can anyone tell me if the following type of ally wheel will fit a 126 Bis
the size is
5J * 13
Tyres = 165/60*13
Your help will be great cheers!
Utterly-Butterly
    • http://www.mcneice.net
Alloy Wheels
« Reply #1 on: January 12, 2007, 09:04:03 PM »
Yes they will, but they are abit wider than the standard ones.
I have fitted a set which are 5.5J on my 126 and they fit perfect.
Utterly-Butterly
Alloy Wheels
« Reply #2 on: January 12, 2007, 09:15:10 PM »
Another thing... you need to check if they are 98PC stud fitting,
Alloy Wheels
« Reply #3 on: January 12, 2007, 09:47:08 PM »
blimey steve, rapidly becoming a a whealth of 126 knowledge!
 :lol:
Alloy Wheels
« Reply #4 on: January 12, 2007, 09:48:43 PM »
also found this
http://www.tyresave.co.uk/tyresiz2.html
allows your to compare tyre size witha  percentage difference of best fit.
Utterly-Butterly
Alloy Wheels
« Reply #5 on: January 12, 2007, 10:28:32 PM »
well I am the son of Master of 126's  :P
Alloy Wheels
« Reply #6 on: January 12, 2007, 10:44:12 PM »
OI IM NOT YOUR DAD!!!
Alloy Wheels
« Reply #7 on: January 12, 2007, 10:49:49 PM »
Apparentley the bolt diameter is 100?
Also what does 98PC mean?
Thanks for all your help!
Utterly-Butterly
Alloy Wheels
« Reply #8 on: January 12, 2007, 10:56:31 PM »
Prove it bis13 :)
With the diameter been 100 the alloys wont fit without wobbly bolts.
98PCD = 98 Pitch Circle Diameter, being the difference between diagonal stud centers. Fiat 126's are 98 PCD
Sorry I missed the D off :P
126cab
Alloy Wheels
« Reply #9 on: January 12, 2007, 10:57:51 PM »
can you prove that bis 13
Fiat 126 Cabrio
Alloy Wheels
« Reply #10 on: January 12, 2007, 11:00:56 PM »
So are these wheela a no go?
Utterly-Butterly
Alloy Wheels
« Reply #11 on: January 12, 2007, 11:04:44 PM »
No go im afraid... unless you use wobbly bolts.
If you go down that route your best person to talk about wobbly bolts is Toz, as he uses them...  though hav'nt seen much of him lately.
Alloy Wheels
« Reply #12 on: January 12, 2007, 11:07:04 PM »
Thanks for all your help!  I think I will leave them, they actually came off a Fiat Uno.
Thanks again
Alloy Wheels
« Reply #13 on: January 13, 2007, 04:13:10 PM »
if they came off an uno and they are factory made they will fit.
Bruce
Alloy Wheels
« Reply #14 on: January 20, 2007, 04:14:12 PM »
those tyres will be slightly to big, you need 55 profiles to keep the gearing and correct speedo reading. either that or go down on the width, whic would probably be better as 165s should go on 5.5Js
