Author Topic: how low can i go  (Read 3645 times)
paulisa
how low can i go
« on: December 12, 2006, 02:52:47 PM »
just fitted a set of 5,5x13 alloys the rears have 185/60/13 tyres the front 165 /60/13 i have chopped 1 coil from the rear springs the back is looking better what i want to know is how many coils can be removed and how low it makes the car also how much can i shave off the front alloy blocks to lower the front or can i just remove them altogether i was looking for 50mm front and about the same rear
Thanks Paul
how low can i go
« Reply #1 on: December 12, 2006, 06:31:55 PM »
Hi Paul, the only way you can lower the front end is to use a reverse eye leaf spring, i had mine modified locally, i have posted the guys i used in reputable company's,  http://www.fiat126club.co.uk/forum/viewtopic.php?t=1574 this gives you a 30mm drop on the front end, dave126 shaved 13mm of the blocks, so in total that gives you 43mm drop, for the rear sping you can cut upto 1.5 coils off.
Look at  http://www.fiat126club.co.uk/forum/viewtopic.php?t=1156
paulisa
how low can i go
« Reply #2 on: December 12, 2006, 06:44:34 PM »
thanks for that I will call smj tomorrow i already use there springs on my suzuki offroader and they seam to be ok i will also shave the front blocks as well how long did it take them to do your spring dont really want the car off the road 2 long
how low can i go
« Reply #3 on: December 12, 2006, 07:17:57 PM »
they did mine in a week, i suppose it depends on there work load, contact names SIMON or KEN. be carefull when shaving the blocks, if you take too much off and hit a bad bump the spring could hit the body in the centre, When they modify the spring you will need a new pair of spring eye bushes as they had to burn mine out, forget going to the fiat dealers they didn't have any in the country, i got mine from axel gerst https://ssl.kundenserver.de/shop.fiat500126.de/indexa.htm
although it took nearly three weeks to arrive, so i'd get them on order first so you can minimize the time the car is off the road
paulisa
how low can i go
« Reply #4 on: December 12, 2006, 08:04:26 PM »
thanks for the tip on the eye bushes i have some spare polly bushes from my suzuki so will see if i can have them turned down to fit the eyes i will get the spring done then see how it sits if i need to shave the blocks then i will do it what should i do for dampers?
how low can i go
« Reply #5 on: December 12, 2006, 08:33:38 PM »
velenti.no one of the guys on the forum said in Poland they put a set of rear dampers on the front because they are shorter and harder but i have hav'nt tried this yet, but the standard ones seems to be o.k. as for the blocks i have left them standard because there there are alot of speed humps around Leeds, the last thing i want is to rip the transverse spring off.
paulisa
how low can i go
« Reply #6 on: December 12, 2006, 09:00:07 PM »
not so many speed humps in redcar and the ones we have are quite tame the road to work is all good flat road but with 26 roundabouts its so much fun passing bmw s round the roundabouts its surprising that they have to get past again almost like they have to prove the bm is quicker than my 650cc s of pure power maybe they get street cred for bragging they managed to pass a 126
how low can i go
« Reply #7 on: December 13, 2006, 12:40:21 PM »
good luck with the lowering........the blocks can easily take the 13mm cut.ive no probs so far.also check out my neg camber mod.add in zero toe in/out and its awsome!
