Author Topic: exhaust mounting plates  (Read 2027 times)
mattlucas
    • http://www.nulifeglass.com
« on: December 11, 2006, 01:55:59 PM »
does anybody know how one would usually get the rear exhaust mounting plate of my biz because mine was broken along with other parts of my car while being seriously abused by my local kwik fit im now having trouble getting the top passenger side bolt out there is no place to undo it im assuming this is why kwik fit CUT IT OFF any help greatly recived
ive looked on the net for new ones but no joy so made ive made some so new ones are not needed
« Reply #1 on: December 11, 2006, 06:40:35 PM »
Hi Matt, is it the rear bracket that bolts onto the head? if so you have to take the starter motor of because the top of the solenoid is in the way, and there is not enough room to unscrew the bolt out all the way.
When you put the plate back on if you screw the bolts up but leave slack, (so it floats its easier to mount the exhaust) re-fit the exhaust, then tighten the bolts up using an open end spanner.
mattlucas
« Reply #2 on: December 12, 2006, 01:25:10 AM »
thanks very much im sending it back to kwik fit as they broke it
