Author Topic: Reverse Eyed Spring Lowers Front By 30mm  (Read 6958 times)
« on: December 03, 2006, 12:54:33 PM »
I had my front spring refurbished and made into reverse eye by these guys, they did a good job and it works well, and it cost less than half the price of importing one, around 50/60quid
P.S. I forgot to add this lowers the front of the car by 30mm
SMJ.
LEAF SPRINGS MANUFACTURERS.
UNIT 5B.
STANINGLEY TRADING ESTATE.
PUDSEY.
LEEDS LS28 6BZ.
Tel 0113-2360396  Fax0113-2612357
mattlucas
    • http://www.nulifeglass.com
« Reply #1 on: December 14, 2006, 09:55:06 PM »
hi there can you tell me do you need any special tools to remove / attach the leaf spring ??
MaLi
« Reply #2 on: December 15, 2006, 12:09:16 AM »
And one question from me:
Is the last leaf spring just up-side down or they have bend both ends of it to make eyes higher? (I cannot see on the foto)
« Reply #3 on: December 15, 2006, 04:40:10 PM »
no special tools needed Matt, a couple of jacks, axel stands, and common sense, be very careful, you must support the spring at each end.
As for the spring Mali, they strip it down and re-temper/bend the bottom leaf, with the eyes on top, then reassemble it.
MaLi
« Reply #4 on: December 15, 2006, 06:51:19 PM »
Thanks!
I am just bit worried that leaf can crack near eyes. I'll wait and see if it will.
If nothing happens I'll do the same to mine   :wink:
« Reply #5 on: December 15, 2006, 09:43:30 PM »
Hi MaLi, the only thing i can say is that these guys have been making and refurbishing springs for the motor trade for years and have all the equipment to do the job properly
« Reply #6 on: December 17, 2006, 03:04:54 PM »
may i add for matts benifit,the lowered reverse eye spring is easier to refit than a standerd one.........but before doing anything,make sure you douse the alloy block studs with wd40 or somthing for a while before you try undoing them.thay have been known to snap.........
sorry for the wose than usual spelling.lm in internet cafe and no letters on keyboard!!!
« Reply #7 on: December 17, 2006, 03:10:29 PM »
use the force luke........ sorry Dave :lol:  :lol:  :lol:
