Author Topic: spacers  (Read 4546 times)
mattlucas
    • http://www.nulifeglass.com
spacers
« on: November 29, 2006, 11:42:59 PM »
does anyone out there use wheel spacers??
spacers
« Reply #1 on: December 02, 2006, 11:53:19 AM »
Have some but not used yet, Better to het the real thing, never seem very safe to me.
Bruce
spacers
« Reply #2 on: December 02, 2006, 10:39:18 PM »
none here and i am running 165x55x13 on cinq alloys, spacers would probably cause them to foul the arches.
spacers
« Reply #3 on: December 03, 2006, 07:55:24 AM »
if you have an offset that is going to foul your suspension spacers are the ticket but if you just want to push the wheels out for a bit of stylin then remember you will have issues with your arches at some point and need to roll them most body shops charge about £50 an arch for this but you can hire or make the kit and do it yourself if feeling brave. just remember to heat the paintwork up gently before you roll to avoid cracking the paint. also spacers can be very cheap or very expensive it depends on what route you want to go down . i know lots of drivers who use these on cars with no problems and doubt if a 126 will cause them not to function as designed if a skyline does nt.
hudsonhenry
    • http://www.retro500.com
spacers
« Reply #4 on: December 03, 2006, 11:44:10 AM »
I have small spacers on my 500 – 126 hubs– to clear the brake calipers on my disk brakes.
toz
spacers
« Reply #5 on: December 13, 2006, 08:33:19 PM »
Hi i have fitted spacers to my 126,spacer bolts)they are 1.25 inches,i have used spacer plates off a mini so they cant undo themselfs,then your other bolts fit into them,(they need to be alloy wheel bolts though).
i have 15s on it and the rear is fine but had to make drastic modifications to the front, :smt022 ,looks like its on steroids lol.
if i could turn the hands of time i would stick to some nice 13s with spacers, :smt075 ,
at least then you could easily lower it and would look great.
i now have to put a kit on mine to componsate the drastic modifications that i made,its so time consuming wish i never made that mistake.
paulisa
spacers
« Reply #6 on: December 13, 2006, 10:02:25 PM »
i bought some solid 10mm spacers from a motorsport shop and longer studs this was just to give me a bit of clearance on the rear as i have 185/60/13 tyres and they were very close to the suspension on the inner side
spacers
« Reply #7 on: December 14, 2006, 09:40:42 AM »
surely with 185 s on the back it must render it impossible to lower the car without some serious arch modifications ?
paulisa
spacers
« Reply #8 on: December 14, 2006, 01:03:51 PM »
3have done no arch mods  at all but have only chopped 1 coil out the wheels now sit more or less straight no positive camber i think it is all to do with the wheel offset mine are 5,5x13 but i needed a 10mm spacer to get the rim off the  suspension arm will post some pics later
mattlucas
spacers
« Reply #9 on: December 18, 2006, 09:05:55 PM »
do you mean you cut the springs ?
do you use standard wheels?
paulisa
spacers
« Reply #10 on: December 19, 2006, 03:40:36 AM »
yes i cut the springs but the wheels are 5.5x13 alloys
