Author Topic: aircooled 'boite de vitesse' mods  (Read 3333 times)
« on: November 09, 2006, 07:09:11 PM »
http://www.fiat500sport.com/default.asp. im thinking of the 'short 3rd 4th and overdrive 5th from these guys.....and also fitting the bis final drive...any thoughts or input???  :cool:
they dont give the ratios
« Reply #1 on: November 09, 2006, 09:46:58 PM »
sounds like an interesting project dave, there's nothing more fustrating than hitting 3rd and 4th and finding that the engine is'nt on cam, i presume that the 4 kits they do are different ratios for different power bandwidths and will need choosing carefully as not to over/under gear the car
hudsonhenry
    • http://www.retro500.com
« Reply #2 on: November 09, 2006, 09:47:04 PM »
Dave
I would try one of the mods at a time, you may not need both.
Nigel
« Reply #3 on: November 10, 2006, 04:53:25 PM »
thanks guys......nigel,your right, i am thinking that my modest HP wont be able to pull bis diff and 5th........so your advise is taken on board.....but my problem is that i only have a bis box spare for the project....and was hoping to build this up on the bench without having the car off the road (again)..........so i guess il need to source an a/cooled box and freight to jersey...........mmmmnnnn :sad:
hudsonhenry
« Reply #4 on: November 10, 2006, 05:26:50 PM »
Dave
Why don't you pull the box out of the car, swap the bellhousings around and re-fit the bis box, then you can see if the taller gearing of the bis is what you are after, if its not tall enough or you want the extra ratio you could then rebuild the aircooled box that will now be sitting on your bench.
Nigel
« Reply #5 on: November 10, 2006, 06:15:57 PM »
DOH! why didnt i think of that!!!...... :oops: i need more stella to clear the brain methinks..............
