Author Topic: Which is the BIS gearbox oil filler hole?  (Read 2692 times)
petal
« on: October 07, 2006, 03:11:42 PM »
I removed this hex-header 13mm bolt, thinking it was the filler hole, ( high up on gearbox, right side in front of the half-shaft.  top-centre in photo)
But then I noticed a rather damaged-looking square-headed bolt (1/3 way up the gearbox, right side, to the rear of the half-shaft. bottom-left in shadow, rather out of focus)
I can't find a clear picture/statement in the BIS CD-manual as to where/what the filler plug is.
I'm inclined to think it's the square thing.  Do I need a special tool for it?  What is the other bolt for? (have I undone something inside the gearbox by removing it?  I hope not...)
Thanks,
Bill
petal
« Reply #1 on: October 07, 2006, 03:50:41 PM »
Another thought:
What if the lower bolt is the filler hole, which also marks the level, but I can't get it out?
Can I fill the box through the upper hole, with a measured volume of oil as specified in the manual?  I suspect that this is risky, as each gearbox case is a little individual so the capacity will vary and overfilling can be harmful.  Is that so?
« Reply #2 on: October 07, 2006, 11:23:59 PM »
Not sure if it's the same on the Bis but here is an aircooled box
petal
« Reply #3 on: October 08, 2006, 09:24:38 AM »
Thanks, it's clearly the lower square bolt.
Now I'm a bit worried that removing the upper hex-headed bolt I've given myself more trouble...
I tried a reversed 1/2" square drive on it, but it didn't fit.  I'll try to buy a special tool, and if that doesn't work out I'll have to make one.
Ta,
Bill
Bristol
banjomandolin
Bis Gearbox oil filler hole.
« Reply #4 on: October 08, 2006, 10:41:20 PM »
You are lucky the square plug is not more mangled. Don't know what you mean by "reversed" 1/2" socket. I always use the 1/2 socket. You may have to hammer it on or file a bit off the plug. It helps if you use a long extension.
John Clark
