Author Topic: air intake cooling needs  (Read 2278 times)
« on: October 04, 2006, 06:16:19 PM »
im fitting a rather gorgous twin cable linkage (from Fast Road cars) on my carb at the mo....now,the only prob im having is that the large air intake hose is in the way...im thinking of doing away with it,and just putting a mesh over the engine part of the intake..........will that be ok ? im throwing this open to anyone with a comment to make,i think it will be fine......famous last words????
bear in mind that i run all the time with the top engine cover open.......
and im going to be lagging the header pipes to keep the temp down a bit as well...........
« Reply #1 on: October 05, 2006, 08:04:29 PM »
well,im having to go with it,the carb linkage is sorted,and the only casualty is that big intake hose...............so,strainer type of thing over the intake should do,might even help the cooling without that big plenum chamber to draw thro...........
