Author Topic: open gate shifter  (Read 3510 times)
open gate shifter
« on: October 03, 2006, 07:40:04 PM »
along with my carb mounts,i could not resist the steel (deeply chromed) open shift gate from nanni.........so,gone is the scaby rubber boot,replaced by a Ferrari-esq shift gate.........sooooo very tasty guys :cool:
just thought id post to recommend the item from NANNI RICAMBI    :D
hudsonhenry
    • http://www.retro500.com
open gate shifter
« Reply #1 on: October 04, 2006, 09:46:18 AM »
Dave
They look fantastic, adds a touch of class to the interior, the only problem I found with them is that the hot air from the heater leaks through the gate.
I dont have a heater at the mo so I am going to re fit mine soon.
Nigel
open gate shifter
« Reply #2 on: October 04, 2006, 03:10:53 PM »
I bought one of those a while back. They look great, the only problem with mine is that i can never seem to get my gearstick to align correcly in it. I have tried adjusting the bolt on the side of the gear linkage, to no avail. I think i may be needing a new linkage though as there is a lot of play with the gear stick and it wobbles an waful lot. Where can one buy a complete gear shift linkage/remote?
open gate shifter
« Reply #3 on: October 04, 2006, 06:08:17 PM »
yes darrel,the alignment......i just fitted the gate to suit the shift pattern......................,as for the demister nigel,well,who gives a sxxt when you have that piece of glory to look at???......... :lol:
open gate shifter
« Reply #4 on: October 05, 2006, 11:10:40 AM »
When are we going to get a look at buzz bomb? PICTURES!!!!!
open gate shifter
« Reply #5 on: October 05, 2006, 05:46:55 PM »
theres some in the 'slag my car' department dave!!....and one in the neg camber thread.......dont wana bore peolple with more!! :lol:
open gate shifter
« Reply #6 on: October 07, 2006, 09:04:41 PM »
should have added,the gate is fitted 9mm forward,and 4mm to the right to suit my mid mounted gear shift,and today i added a piece of rubber sheet(slit cut in the shift pattern) to blank off the hole that is left,that sorts the de mister prblm...........
