Author Topic: Annoying Electrics  (Read 6080 times)
Annoying Electrics
« on: October 01, 2006, 03:09:12 PM »
Hello all,
Firstly, at the risk of sounding like a complete novice (which i almost am), what is the job of the coil in the 500/126?
I have a reasonable knowledge of these air-cooled engines, on the mechanical side, however the electrical side completely throws me. I have recently put in a 652 (126) engine in my 500, put in a fast road camshaft, installed a FZD 28/32 carb, sports clutch and alloy sump, but have not altered the electrics (still mechanical starting).
After a lovely drive through central London on Friday evening, in the appalling rain, my car just decided to completely loose power and cut out on waterloo bridge. The electrics and engine completely cut out and would not restart. I had to join the AA there and then and get a mechanic to come out. He checked the battery and it had a full 12.5V charge, but the engine would not turn whatsoever. As soon as jump leads were connected though, it started instantly and was fine all the way home. However when I got home and turned off the ignition, it would not restart. After a stressful nights sleep trying to figure put what the problem was, I tried starting the car in the afternoon and it started fine!
At this, I figured that maybe it cut out due to the bad rain and water shorting the electrics, either at the starter or around the dizzy. So I carried on using the car as usual the following day and night. Then after filling up petrol, I turned on the ignition, gen light on as usual, then pulled up the starter, and nothing, as before, it just would not start, giving the symptoms of a totally dead battery. It is most annoying as I use the car daily.
The battery is only a few months old and appears to be fully charged as it was before. The alternator also appears to be charging the battery (No gen light when revving + just over 14v output charge).
Could anyone shed any light on what this problem could be as my knowledge of the electrical workings of this engine is not too great. Could it be a dodgy coil or condenser or something?
It is even more frustrating as it is temperamental, starting fine sometimes, whilst completely failing at others, so I fear I could take it to a mechanic for him/her to fiddle around a bit and charge a lot of money, only for him/her to find it working - as if he/she has fixed it, then find it failing me again after I have brought it home.
Please excuse this colossal essay of a message,
Kind Regards,
Annoying Electrics
« Reply #1 on: October 01, 2006, 04:48:14 PM »
Dom,
It would not be the coil/condenser causing the problem.
It sounds very much like a starter motor problem; it’s worth checking the lever on the starter motor when the problem happens again. Try pushing the lever which is on the starter motor and see if the starter motor operates then?
Also check that the engine is earthed correctly there is a lead somewhere from the engine to the vehicle body.
I strongly suspect that it’s a starter motor problem because of the intermittent problem and probably the best cure is a replacement or reconditioned starter.
Good luck, any other concerns just ask.
C
P.S Have a peep at this thread
http://fiat126club.co.uk/forum/viewtopic.php?t=1267&highlight=starter
Annoying Electrics
« Reply #2 on: October 01, 2006, 04:56:00 PM »
sounds like a bad earth somewhere to me(the AA mans batt may have given such a belt of current that the earth re earthed its self by welding a little).or that mechanical starter motor...........wont be coil etc tho, i agree with cars.did you try push/roll starting it when it was dead?
oh,and nice work with the mods!!!..... :cool:
Annoying Electrics
« Reply #3 on: October 01, 2006, 06:23:28 PM »
Hey, Thanks for your quick replies,
I will definitely have a look at the starter and earths and give them a clean. I just didn't think it could be the starter as it starts instantly when it is jump started with another car. This morning it wouldn't start again, so I loosened and cleaned all the conections on the coil, the condenser, the distributer and noticed a nut on the alternator was loose. I tightened all these, put in new washers and sprayed them wd40. It didn't start, even though the battery was reading 12.4v. I then jumstarted it and took it on a 30min drive. It appears to be starting fine now, but will try again tomorrow.
Annoying Electrics
« Reply #4 on: October 01, 2006, 06:31:21 PM »
Oh, and also is it possible that it could've been water getting into the electrics and causing a short, (either over the dizzy, or somewhere else below the car) that caused it to loose power initially in the first instance? I say this as it was really raining hard and the puddles on the road would've required waders to walk through!
Also, did try to push start it, but I have never been able to successfully push start (poor technique by me I think!)
Thanks again
Annoying Electrics
« Reply #5 on: October 01, 2006, 07:05:26 PM »
i dont think its the rain, the engine heat would of got rid of any moisture so should have started fine again.
I think it could be your starter cable, mine wasnt engaging when i pulled it up, and if i pulled it hard and quick enough it would start, try putting your ignition on then open the engine lid and push the starter to make contact and see if that works. If it does make a grinding sounds/motor working, then it must be a stretched starter cable or the clip underneath has broken.
you sure the car is only not starting  when hot? After its cooled does it start fine again? If it does would suggest fuel problem i.e. fuel pump.
also if you want to bump start it, get it on a hill or get someone to push you, put it into 2nd, clutch down then bring the clutch up when there is enough momentum, then get your foot on the accelerator!
regards
Bruce
Annoying Electrics
« Reply #6 on: October 01, 2006, 09:46:31 PM »
a possible cause of intermitant starting on this type is a missing/broken/diconected earth strap; the starter  or clutch cables sometimes makes an earth and sometimes do not.
Annoying Electrics
« Reply #7 on: October 02, 2006, 09:44:38 AM »
Definitely gonna go with the earth at the moment. Will swap the little engine earth wire for a larger, more durable earth strap + clean the connections. Will also clean and check the negative earth from the battery and its connection and also is there an earth on the starter motor? I know I have 2 cables attached to it (thick brown and thinner black).
Bruce
Annoying Electrics
« Reply #8 on: October 02, 2006, 03:18:02 PM »
can't remember, its years since i owned an aircooled. My bis starts on a key (or at least it will do once i sorted out the fuel system).
Annoying Electrics
« Reply #9 on: October 02, 2006, 05:32:52 PM »
''Will swap the little engine earth wire for a larger, more durable earth strap + clean the'' ...........
mmnn.there should be a big copper earth strap from the block to the rear panel...i took mine off,soaked it in petrol, then thinners,dry it then sanded the ends clean............i think the 500 should have the same????
Annoying Electrics
« Reply #10 on: October 02, 2006, 05:52:36 PM »
Mine does have the copper strap now. Took it off an older engine i had knocking about. Before it had a wire doing this job instead. Seems to be working very well now. Lets hope it stays that way. Gonna try and put the old 126 back together now as 2 cars are surely better than 1.
thepmf
Annoying Electrics
« Reply #11 on: October 03, 2006, 07:14:58 PM »
watching this thread with interest. my air cooled does just the same. i'm convinced that its the starter motor, cuz if i thump it (with the hammer i carry for just this occasion) mostly it's off again for another few days. as you can see i'm a propper mechanic, got big hammer & a condom (punch line by request for anyone who needs a hand).
Annoying Electrics
« Reply #12 on: October 03, 2006, 07:26:20 PM »
im still on the earthing side of things,bear this in mind,if your earth strap is missing /whatever,the engine will be earthing thro the throttle cable/choke cable(as bruce said)............so do you want your electrical earth to be thro your carb??? :shock:.now,banging things with a hammer and then they work,that also sends me down the earthing route.
reminds me of morris minor and their fuel pumps....a mate had one,then moved on to an early subaru pickup,it packed up,he 'tapped' the (mechanical) fuel pump and sheared it off the block!!!!..i dont tend to hit things anymore...........
thepmf
Annoying Electrics
« Reply #13 on: October 03, 2006, 07:54:53 PM »
Point taken dave, i must extend my tool collection and get my hands mucky. :roll:  joking apart, i have got a nice copper earth strap, but its green, so i supose i'd better give that a clean as described earlier in the chat, but i did take it off and clean the connections. Am on the hunt for a vaultage regulator just now, my gen light is glimmering on tick over and becomes gradually brighter as the revs are increased, d'you think i'm on the right lines? p.s. had dynamo reconditioned just recently! :?:
phreak97
  • Niki!
Annoying Electrics
« Reply #14 on: July 16, 2007, 03:44:34 PM »
i've heard of people tapping a starter motor before, i think it does fix it if theres a problem with it sticking so it wont engage, in which case it probably wouldnt run either.. im not sure, im not up to starter motors yet, im learning things as i need to, and i think the mechanical startr in my topolino will be next. the range of the lever on the motor is longer than the length of the knob.. which is odd cos its an original knob. anyway, i get to choose between either having to pull it a mm past where its maximum should be to make it start, or the starter not disengaging properly after it has been pushed back in.. it stays engaged for a couple of seconds before disengaging. i think its probably a problem with whatever electric switch is at the motor end to tell it to turn on. ill find out more when i open it up.
anyway, tapping a mechanical starter wont do anything i dont think, maybe for an electric one though.
my girlfriends mums car had that problem, i think a mechanic actually told them to do that when it wouldnt start, at least until they could afford to get it fixed.
phreak97
