Author Topic: Piston liner kit  (Read 8166 times)
Tomasz
Piston liner kit
« on: August 14, 2006, 08:13:25 PM »
Hi guys
What do you think of the piston liner kit on www.fiat500sport.com ?
I plan eventually (when im not a student) to have a full abarth engine built but until then is this worth saving for?  It says it gives 40hp.
Im no great mechanic so some opinions on this would be really helpful.  Is there a cheaper (but not botched) way of getting the same results?
Piston liner kit
« Reply #1 on: August 14, 2006, 09:33:13 PM »
i dont know a lot about the twin,but,there are a lot of bad vibe issues to think about at that output level.....i think you need to progress to steel crank and dino rods/full balencing etc at the same time as the bigbore kit.
i have only fitted a panda head,fast road cam,sport exhaust and 40 dcoe weber to mine,(30-33bhp?)but have been warned to keep the rpm's down to 5000-5500...and expect shorter engine life, thats with an oil cooler and extra cooling aids..........in reality i try to keep it to 5000..but the odd burst of fury takes me on,on,on,on  :twisted: (sounds great at 6k :shock: )
that kind of output (30 ish bhp) is ok really,and you can use it more if you tune the chassis as well.....thats my approach....to keep it in the carpet as much as possible.....................
other more learned peeps on here may help you.
Tomasz
Piston liner kit
« Reply #2 on: August 17, 2006, 10:05:24 AM »
Yeah this is what italcorsa suggested:
‘The 800cc conversion will give you the HP required, but it is not known for its reliability.
The next best thing is a Dell'orto 30/32 FZD Carb, fast road camshaft & fast road exhaust.  If your engine is in good condition this will return 30BHP at a reasonable cost.’
Think I might save for this option for next year but any other suggestions/additions would be great.
PaulB
Piston liner kit
« Reply #3 on: August 17, 2006, 01:32:34 PM »
Dave's hit the nail on the head. There is little point in sticking monster racing pots on a road engine - engine rebuilds are routine for racing teams - an expensive pain in the arse for everyone else. Besides, you'll shoot through the gears fast enough with the extra bhp, but you'll hit the same problem as you would with a more durable and cheaper mod like Dave's - RPM.
You need to look at the transmission at the same time as the BHP. If you have plenty of BHP, then 5th gear and/or a BIS box will be a good move.
The stock engine is limited to about 4500 rpm by the Weber 28 carb. A better carb and exhaust frees up the breathing and the revs - so you'd need a rev counter - 6000rpm is 25% more revs than the engine is designed for - expect trouble. Theres only so much you can do for a straight twin - it is not a design used for high rpm as the stresses and vibrations are much higher than a V engine.
Piston liner kit
« Reply #4 on: August 17, 2006, 04:25:00 PM »
its a nice idea to wack, some new bores in and think the car will go a bit faster, but im sure its not as simple as that :( the engines have been designed to how best they will run, so i cant see wacking an after market thing in will be worth while(unless it was made by Karlo Abarth himself ;))
best thing anyone can do is maintain the car themselves, i.e. plenty of oil changes.
Piston liner kit
« Reply #5 on: August 17, 2006, 04:41:49 PM »
PaulB
Piston liner kit
« Reply #6 on: August 17, 2006, 10:50:13 PM »
This is what I'm asking santa for - then I'll fit the panda head I've got tossing about...
http://www.fiat500sport.com/dettaglio.asp?a=0112&t=2&l=ENG&sku=331391D31A69
hudsonhenry
    • http://www.retro500.com
Piston liner kit
« Reply #7 on: August 17, 2006, 11:10:41 PM »
Quote from: "PaulB"
Have a look at these guys, they do race gears, first class quality I am told
http://www.bacciromano.com/index.htm
I am putting together a shopping list myself
Nigel
Piston liner kit
« Reply #8 on: August 18, 2006, 07:51:47 AM »
paul,if 3rd and 4th are ''short'',how long is the 5th going to be??......id check that before taking the plunge,they might just be closer gearing to take care of a narrower power band on a highly tuned motor,as i understand it,your looking for an 'overdrive'?...................
you might be ok with bis dif and 13'' wheels????
this must have all been done before in italy and poland,shame that we cannot tap into some old info on this.....for example,i could tell you to fit a Riley 1.5 diff in your tuned morris minor/sprite/midget axle to get better cruising...........or  an austin A30 diff for acceleration...............(used to do that on mine)
the panda head is good,bit i dont think good enough to handle an overdrive or high/low 5th......you thought about fitting a bis motor??? very torquey when they are going,they pull like a steam engine ! LOL  :wink:
slater
    • http://www.retro-rides.com
Piston liner kit
« Reply #9 on: August 19, 2006, 10:30:01 AM »
Is the BIS box any better than aircooled then? capible of taking more power? taller final drive better ratios?
Im building my engine to drag race so relly im looking for a strong box with good ratios and a low final drive for acceleration.
Piston liner kit
« Reply #10 on: August 19, 2006, 01:21:00 PM »
no they are as weak as each other!! but the bis has a lowere final drive for higher cruising speed...the bis engine makes more torque
hudsonhenry
Piston liner kit
« Reply #11 on: August 19, 2006, 05:20:08 PM »
I am in the process of trying to decide whether to rebuild a BIS box (with 500R bellhousing) or rebuild the 500R non syncro box with the crownwheel and pinion from a BIS. At the moment I am hitting just over 90mph with a little more to go but must be pulling around 7000rpm – no rev counter fitted – (at 80mph with the aircooled I was over 6000rpm). I definatly have the power for taller gearing, 1st isn't used at all at the moment.
As I understand it the non syncro boxed are stronger because the gears were made thinner to make the space for the syncro, not that the non syncro ones are much stronger. Only problem is that I am rubbish at downshifting without syncro!
Slater if you want to drag race it then the syncro isn't so important, but why not fit a VW engine and box? I had a good poke around Little Whopper the VW powered 500 drag-racer at the weekend and it all just about fits. Does the quarter mile in low 12's while pulling massive wheellies, you will never make a 126 box anywhere near that strong).
I'm also working on a conversion from the alloy and rubber donuts at the end of the drive-shafts. We are going to replace these with CV joints and custom made drive shafts – torsion bar material. I did think about removing the rubber from the donuts and replacing it with silicon but I need to do some research into the strength of silicon in sheer, I know its stronger than rubber in compression.
Piston liner kit
« Reply #12 on: August 20, 2006, 07:04:41 AM »
I know nothing about what you are all talking about.
But!
I am member of a VW forum and most of the swear by a company in west London  'Cogbox'. They make and modify gearboxes to fit anything.
Maybe they could help out.
hudsonhenry
Piston liner kit
« Reply #13 on: August 20, 2006, 08:42:37 AM »
Quote from: "dajwid"
most of the swear by a company in west London  'Cogbox'. .
Dropped the boxes off with Peter from Cog Box last Tuesday for him to strip down and venture an opinion on.
Piston liner kit
« Reply #14 on: August 20, 2006, 08:11:23 PM »
keep us informed! I have a couple of ideas bubbling away in my head at the moment.
Got my UK 126, 5 tons of parts. But gearbox mods I'm lost.
