Author Topic: newbie help required!!  (Read 6495 times)
Mike Simcox
« on: August 14, 2006, 05:46:21 PM »
Hi all
dont know if you can help - as I may not be your type of thing, I know how funny we can be on our Forum (Scirocco Register) if someonekills a car to make something else!
Let me explain.
I have an MCA sports - a fiat 126 based convertable. All its mechanics & parts are 126 - but fitted in a box section chassis & fibreglass body.
I took it on as a non runner & have fixed  the few odds & ends to make it run - not easy when parts of it are in bits & you dont know what goes where!!
So.
My last few dilemmas are:
starter cable - there was one part fitted but I couldnt work out its route or exactly how it fitted. Thought I had sussed it but it sparked out on the starter motor & melted...... DOH!
Simple thing I know - but never having seen it in situ & not finding an obvious route or anything I'm stuck. I will need to buy a new one anyway! Or is there a way to change to a solenoid one?
Brakes.......
Can these be updated? Improved?
& I MAY need a headlight will have to look at the reflector..... Best place?
cheers in advance guys - if anyone wants any Scirocco help give us a shout! ;-)
Mike Simcox
Scirocco Register Founder.
Mk1 Scirocco VR6, Escort Van, MCA Sports
« Reply #1 on: August 14, 2006, 06:39:58 PM »
hi mate,for all your parts needs,use axle gerstl in germany,good service and fast delivery if in stock,brakes are easy to update to discs,try nanni ricambi in italy.
nice that you are taking the time to refurbish the MCA,dont worry,it was the previous owner/builder who commited the sin of scrapping an aircooled!!!................
feel free to contact me as for any other tuning info,i've done the odd little bit to my 650 126..... :cool:
Mike Simcox
« Reply #2 on: August 14, 2006, 08:03:25 PM »
Thanks Dave - appreciated.
My first port of call I think is to get the thing MOT'd. not much left to do really. As I said may need a headlight & finding out how the bloody starter cable goes in - some on ebay for a fiver but still need to know what route it takes & where it fastens in. I purchased a floorplan that the body had been removed from to make a jeep type thingy but never done - when I get the opportunity to ship it up here that may hold some clues to some stuff. Just working blind on little things you cant find out without looking for yourself sometimes!
Where do I find axle gerstl & nanni ricambi - links on here somewhere ( before I start looking!)
Thanks again
Mike Simcox
Bruce
« Reply #3 on: August 15, 2006, 10:31:48 PM »
i had a fire on my old aircooled from a shorted starter cable, ran around for a few weeks without a starter, no prob though as it bump started in less than a car length.
As for your problem, not sure if it would work but wouldn't it be possible to fit a BIS starter as that has a more conventional starter, i.e. it uses a key  :)
Mike Simcox
« Reply #4 on: August 16, 2006, 01:47:49 AM »
that would be cool - I cvould just wire a starter button in    -  anyone know?????????
Mike Simcox
PaulB
« Reply #5 on: August 16, 2006, 10:37:29 AM »
The later aircoolers has a solenoid starter - will just bolt straight on to any 652c bellhousing - I may have the bits for one somewhere as I converted a solenoid one to a pull start to fit my 500.
Mike Simcox
« Reply #6 on: August 16, 2006, 06:42:36 PM »
cool!
let me know if u have........
Mike Simcox
PaulB
« Reply #7 on: August 16, 2006, 07:50:56 PM »
I've just rumaged through a pile of parts and found a complete solenoid starter from an aircooled 126 - it needs cleaning up and testing - I won't have time until after the Bank Holiday.
Where abouts are you?
Mike Simcox
« Reply #8 on: August 16, 2006, 08:18:40 PM »
cool!
I am probably MILES away ( usually am from most!) Scarborough in North Yorks.
Post?
Mike Simcox
PaulB
« Reply #9 on: August 16, 2006, 08:21:45 PM »
West Yorks  :D
Mike Simcox
« Reply #10 on: August 16, 2006, 09:02:12 PM »
cool. Not too bad then. Just a case of time to pick it up!
Unless you come across this way @all?
mail me:
mike at scirocco register .co .uk
Mike Simcox
Mike Simcox
« Reply #11 on: August 20, 2006, 09:00:53 AM »
Howdy do....
Never got mail?
Any chance you could post the item to me?
Very much appreciated
 :wink:
Mike Simcox
nandezcreations
    • http://www.nandezcreations.co.uk
« Reply #12 on: October 28, 2006, 09:27:32 PM »
Mike,
I also have a Dash MCA 600 that is in for restoring. I was given it by someone as the owner wanted it removed from their drive.
I run a small company that builds kit cars and race cars to order. We also do restoration projects (three in at the moment, an original lotus 7, a lambretta, and the MCA).
Should you run into any problems with your project then get in touch and i will see if i can help.
As for you stater lever. It runs along the centre tunnel and sits just behind the handbrake lever. The choke is also located in the same position to the left of the tunnel.
If you want to fit a starter motor with a solonoid all you will need electrics wise (excluding the starter and solonoid) is a relay, some cable and a button.
A basic relay will have 4 pins. A 12v supply, an output to your starter motor and the two control pins. If you connect the input control pin to 12v post the ignition key it will stop the engine from being turned over unless the key is set to run. The last pin is connected to the switch. The output of the switch is then connected to earth.
Hope this helps
Miguel
At Nandez Creations we build road, race and kits cars to order. We also offer restoration on almost any type of vehicles and completion of exhisting projects.
Mike Simcox
« Reply #13 on: October 29, 2006, 07:44:34 AM »
Cool!
I have a complete engine - that 'looks' fro the outside better as the one in it ahs allsorts of nuts & bolts missing. It is still sat in the 1/2 car I bought so I am gonna see if it runs just gotta swap the dizzy over & stuff as it is electronic ignition but has some bits missing. If so I will swap the engine it also has a solenoid starter on so I will be wiring that into a button as suggested. Just gotta find the time!
since u r just down the road at barnsley - it'd be cool to see another one some time. I am way too tall for it with the current seats ( Honda CRX) & may never be short enuf - but will be looking for some lower seats to attempt to get my lanky arse in it!
I a sure I will be in touch
Mike Simcox
nandezcreations
« Reply #14 on: October 29, 2006, 09:13:01 AM »
You are welcome to come over. I am going into work today to have a play with it. The dizzy needs cleaning as it is stopping me from getting a decent spark. The brakes have stuck somewhere but if i can get them freed up i am going to give it a spin around the industrial estate.  :D
I am 6' and i can fit into this one. How tall are you?
