Hello, I'm a newbie with an early 594cc model on an 'M' plate (1973), in maroon with tan interior, standard and in pretty sound condition for her age. Inherited from my grandparents, the mileage is just 26,000 since new!
I was wondering if anyone knows how to go about identifying the build date of these cars? It is chassis no. 4081199 and engine no. 4069433. I tried contacting Fiat head office, but got no response.
According to the registration document, it was first registered on 17/12/73 so unfortunately misses the DVLA's cutoff point for tax exempt status - unless I can prove otherwise, hence the question!
Alas, there appears to be a strange problem whereby the (Magnetti Marelli) ignition coil gets very hot, causing the car to gradually lose power and ultimately conk out altogether until it's cooled off - which can take a good half hour or more. Does anyone know what might be causing this? I've checked the points gap and condensor, even tried fitting an electronic ignition module (which did away with the condensor) and a different (Lucas) coil, all to no avail. The problem somewhat limits the car's useability, so any tips would be appreciated...
Cheers!
