Author Topic: Fiat 126 Bis Engine Needed  (Read 3156 times)
« on: August 10, 2006, 06:55:34 PM »
Just joined and was wondering if anyone could help.  I need a running Bis engine, i am in the leicester area and could collect!!
My Bis ran fine till the gasket blew, took of head to fine out only seven studs were holdin' it on, 8th stud was sheared off and someone had pluged the hole on the head with a bolt!?!
Anyway hope someone can help!
« Reply #1 on: August 10, 2006, 07:13:44 PM »
hi,dont throw your motor,take the broken stud out and rebiuld it!
« Reply #2 on: August 10, 2006, 07:28:15 PM »
yer just drop the engine and drill it out.
« Reply #3 on: August 11, 2006, 10:02:48 AM »
can you get us a pic?
see whats happened
regards
« Reply #4 on: August 11, 2006, 11:06:45 AM »
It may need a helicoil if the thread is stripped? It's cheaper and easier than a replacement engine.
Nurudin
« Reply #5 on: August 11, 2006, 09:41:38 PM »
There are only seven bolts on my engine head. I have noticed this just a few days ago. I have the eight bolt in my car. Its been there since I got the car but just recently I figured out where it came from. It has snapped just an inch from the bottom on the thread end. The thread is still in. This was done by a mechanic for the previous owner. The car runs fine. Plan to do it when I get little more mechanical practice.
banjomandolin
Bis Engine for you.
« Reply #6 on: August 13, 2006, 11:20:47 PM »
    I have a spare Bis engine and am in the Leicester area (Quorn). The engine is in pieces and  needs a new front crankshaft main bearing, thrust washer, crankshaft oil seals, timing sprockets, valve stem oil seals and valves regrind. The engine ran well in the car before I removed it but was suffering from oil blowing past the pistons and pressurising the rocker box.
It would be much better if you could follow a previous suggestion and remove the broken stud of your present engine, fit new stud cyl. head gasket and retorque which will be far less cost than refurbishing my engine. I can help you with this operation if you wish. Ph. me on 01509 554337.
John Clark
« Reply #7 on: August 13, 2006, 11:31:53 PM »
i wish you lived in my area john!!!  :lol: dont fancy a trip down to London do you haha :)
regards
