Author Topic: Modded engine  (Read 3357 times)
Virgil
Modded engine
« on: June 01, 2005, 08:59:00 PM »
Hi, I'm after a modified engine for the rally car. If you have anything or know of anything please carry on the thread. I have a watercooled BIS, but if an aircooled will fit the gearbox and other mods eg, mountings, are easy to change I'd be up for an aircooled. Cheers!
slater
    • http://www.retro-rides.com
Modded engine
« Reply #1 on: June 02, 2005, 10:33:08 AM »
I dont think the aircooled engine will fit a BIS box but it may be possible to swap both engine and box for the aircooled ones athough you may aswell just buy a whole aircooled car if your going to do that.
The aircooled engine is easyer to tune and they come up on ebay quite frequantly.
The BIS engines are a nightmare reliability wise as im sure you know o this limits what can be done with them alot.
If you retain the bis engine you could start by fitting a better exhaust (may aswell be just a pipe if you rallying!). FIt a better carb and filter, maybe port the head and lighten the flywheel.
 :D
