Author Topic: The Bis Thermostat Housing.  (Read 1988 times)
banjomandolin
« on: August 07, 2006, 12:18:41 AM »
What a great idea forums are for sharing knowledge. The helpfull advice I received in answer to my query regarding Ricambio's Thermostat Convertion Kit has dictated what action I am going to take. There is also another factor in the equation which I have not seen mentioned and that is the fact that the thermostat housing location is such that it is vulnerable to the icy winter blast of air under the car which will help to delay thermostat opening long enough for the cylinder head gasket blow. I intend to adapt some pipe insulation to enclose the housing and attached pipework.
John Clark
« Reply #1 on: August 08, 2006, 12:25:32 AM »
hi John, good to see you posting on here, i think the insulation is quite a good idea, it might make it open earlier, but i really wouldnt go to too much bother, i drive my BIS everywhere, the needle never goes above just before the half way point on the temp gauge, get lots of gd quality coolant and clean that thermostat/housing out often. (i know its a hassle)
Lots of good oil changes always help. oil its actualy a big part of cooling too. Some people run the heat to take the hot water away from the cylinder head to the front of the car, i personaly dont find it makes any difference.
Also keep the cylinder head well torqued down,  and if use a non asbestos copper headgasket which ricambio sell, they expand with the heat rather than split like fibrous ones. Also keep the timing spot on, if its running too fast it will heat up quicker.
I hope these tips help John, let us know if you put insulation round the thermostat housing and if it helps, also get a few pics for us to see.
regards
