Author Topic: She wont turn over  (Read 1779 times)
shagmeister
She wont turn over
« on: January 31, 2022, 09:47:01 AM »
Morning all
New Nikki on the drive, 96 polish.
She was running before i bought her.  But now will not even turn over.  "Key code" is showing on the dash, but it was when it was running when i bought her.
Any advice on where to start?
Engine turns over by hand.
Minijohn
Re: She wont turn over
« Reply #1 on: February 05, 2022, 05:45:17 PM »
How many keys do you have?
If 2, have you tried them both?
Is the battery fully charged - have you tried jump leads from another car?
When you turn the key to start, do the oil/ign warning lights go out or go dim?
I'd try a lead from the battery positive direct onto the starter solenoid (to the small terminal) - that bypasses the key switch and the wiring between the battery and the starter. The engine should now turn over.
ronb1967
« Reply #2 on: February 06, 2022, 10:52:32 PM »
whats the key code look like ive a 99 polish aircooled and no immobiliser fitted as standard and the ignition keys certainly dont have the chip fitted
