Author Topic: Brakes stuck??  (Read 1767 times)
Goat Girl
Brakes stuck??
« on: April 18, 2021, 05:09:05 PM »
Hi, can anyone help?  I started my Biz this morning and the brakes appeared to be stuck.  After a while I managed to get the car out of the garage but the same thing is happening again - don't want to try too hard in case I do damage.  Apart from a quick nip out of the garage every few weeks over the winter she has done nothing.  Thanks in anticipatation!
Re: Brakes stuck??
« Reply #1 on: April 18, 2021, 05:15:27 PM »
Which brake is sticking? Front or rear?
Goat Girl
Re: Brakes stuck??
« Reply #2 on: April 18, 2021, 05:23:46 PM »
I can't really tell, sorry.  They are not completely stuck but I have to really rev to get it to move.
Re: Brakes stuck??
« Reply #3 on: April 18, 2021, 06:45:11 PM »
Take it for a short spin, then feel each wheel to see which ones are hot.
Goat Girl
Re: Brakes stuck??
« Reply #4 on: April 18, 2021, 07:08:43 PM »
I'll give it a go!
Goat Girl
Re: Brakes stuck??
« Reply #5 on: April 18, 2021, 07:32:56 PM »
The front driver side is getting a little hot.  It did free up a little after going up and down the road but still sticking on the downhill, in neutral with the clutch down?? Is it a garage job as I'm no use?
Re: Brakes stuck??
« Reply #6 on: April 18, 2021, 11:06:16 PM »
Try jacking that wheel up and see if it spins freely. If you are not mechanically minded you will have to take it to a garage to get it checked, maybe a seized slave cylinder?
