Author Topic: No spark  (Read 2689 times)
Bradpitt
No spark
« on: July 29, 2006, 05:42:35 PM »
I have a 126 Bis engine and cannot get a spark at the plugs. I am having difficulty getting my head round how this electronic coil works.
I have 12v at both low tension terminals at the coil before and during turning over. I have reset the points gap and have 12v present going to them. I can get a spark if I short the contacts gap with a screwdriver, but i have no spark at the contacts during turning over. Should there be one?
Any ideas?
Thanks guys
PaulB
No spark
« Reply #1 on: July 29, 2006, 09:30:30 PM »
There's a few possibilities. Firstly, be careful handling live HT leads and plugs - the voltage is very high and you'll get quite a jolt if you form part of the ciircuit.
Check the earth - normally a braided strap from the engine to car body.
At the distributor, check the points are set okay and there is a spark - easier seen in the dark. Also if you have a distributor cap, check its condition and that the contacts for the leads aren't wet or full of oil.
Clean all connections at earth, coil, distributor, leads, coil and plugs and check no wires are damaged.
Also check the battery is well charged.
If the battery is okay, remove a spark plug and place the spark end of the plug in contact with the engine so it makes good contact. Making sure you are clear of fan belts etc, get someone to turn over the engine while you are watching the spark plug. It should produce a blue spark. If no spark, or a weak yellow spark, then there's a problem with coil, rotor/cap, condenser, leads or spark plugs  - swap them with known good ones, one at a time until you track it down.
Hope this helps.
Bradpitt
No spark
« Reply #2 on: July 30, 2006, 10:49:52 AM »
Thanks Paul
As an "old fogie" I am pretty familiar with testing for sparks with the "conventional" rotor arm, dist cap, plug lead system - it's just these newer gadgets that confuse me !
I have found the problem. I removed the distributor so that my poor failing eyesite could see the contact points a little better and found that one side had worn down below the level of the arm it was fitted too. This meant that I was setting the gap miles too wide. Reset it 'properly' and - voila - spark is back!
Thanks again - great website guys - keep it up!
