Author Topic: Air intake parts missing?  (Read 1523 times)
mrboj
« on: May 21, 2020, 03:05:40 PM »
Apologies if not using the correct terminology. Just acquired a 1990 RHD and there appears to be missing some hoses that belong to the air intake? I think I am missing 2. Can anyone point me to the correct part number or shop I can acquire these?  Really eager to take this on the road again but I think its not a good idea until these hoses get fitted?
I found something on ebay here for the right side but not sure if this would be sufficient? If so I assume 45mm is the correct size?
www.ebay.co.uk/itm/301742462766
mrboj
Re: Air intake parts missing?
« Reply #1 on: May 21, 2020, 09:18:48 PM »
The resources available to member is very helpful. If anyone is wondering, the part numbers are 7607498 and 7611281. Now time to source!
Njkip
« Reply #2 on: May 21, 2020, 09:48:15 PM »
Hi, I trawled all over for the hose on the left, going into the air filter box, had no luck whatsoever so ended up making and mend with some modern hose. The one on the left, I have seen pictures of that hose been replaced by a modern equivalent, sort of 90 degree bend, in fact it was in that blue silicone hose, just a thought if you get stuck....🤷‍♂️
