Author Topic: Duck quack it...  (Read 1314 times)
Me_and_BIScuit
Duck quack it...
« on: April 05, 2020, 06:14:40 PM »
After working on BISquit's engine, I had it attached back to the bell housing (top two bolts for now), but then realized that I probably should make sure the flywheel is in the proper position (holes opposite of top cylinder), so out the engine goes, but... it won't budge. The top half seperates a little more than a half inch apart but the bottom half appears to be stuck. Fearing I might snap that bottom headless bolt, I put the top half back together and it's been sitting like that since.
Any suggestions?
« Last Edit: April 05, 2020, 06:16:33 PM by Me_and_BIScuit »
Me_and_BIScuit
Re: Duck quack it...
« Reply #1 on: April 06, 2020, 01:23:40 PM »
Nevermind, I pried it loose. The problem was that I was just barely able to reach that spot underneath just below near the shield (the engine sits on my creeper and some wood, which also was a little bit in the way) but I made it work somehow.
