Author Topic: 126 bis Strange noise coming from the engine  (Read 1801 times)
Boomer
  • Powered by the 6th of a flat 12
« on: October 29, 2019, 04:39:51 PM »
It's a metallic sound, a bit like turning metal on a lathe without oil !!!!  :o
I can ear it above 2000 rpm.
The engine run perfect.
It's not gearbox or clutch related.
It's not the pulley but it seems to be coming from this area.
Any idea ? Thanks
Re: 126 bis Strange noise coming from the engine
« Reply #1 on: October 30, 2019, 12:54:43 AM »
Not allot to go on  :headscratch: Post a video
Boomer
« Reply #2 on: October 30, 2019, 09:37:15 AM »
Well case solved. It's a leak at the front manifold Weld. The crack has an hair size line but a leak sure enough. I had plenty of manifolds leaks in the past, but never with this kind of metallic sound.
